Height control
928 14 2022-11-3
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
If you continuously fly 5 meters in front and back, then the drone gradually gains altitude.
2022-11-3
Labroides
Flight distance : 9991457 ft
Have you got any recorded flight data to show this?
2022-11-3
Drone.Hunter
Kazakhstan
Labroides Posted at 11-3 20:41
https://drive.google.com/file/d/ ... nQ/view?usp=sharing
2022-11-3
GaryDoug
Flight distance : 1264639 ft
Mini2 did the same thing for me. So I gave it away.
2022-11-3
Labroides
Drone.Hunter Posted at 11-3 21:00
https://drive.google.com/file/d/1pYg52oLTykyy5OVAcc88zpgTRY9Ci1nQ/view?usp=sharing
1.  A video is not recorded flight data
2.  Your video doesn't play
2022-11-3
Drone.Hunter
Kazakhstan
Labroides Posted at 11-3 21:12
del.
16m-17m
2022-11-3
Labroides
If you tick the share box and post the link again, I'll be able to see the actual data and get an idea of what's happening.
2022-11-3
Drone.Hunter
Kazakhstan
Labroides Posted at 11-3 23:17
https://app.airdata.com/share/pLWfpf
16m-17m
2022-11-3
DAFlys
Push the left stick down to reduce altitude.
2022-11-4
Drone.Hunter
Kazakhstan
DAFlys Posted at 11-4 00:48
I understand it. But is this how it should be?
2022-11-4
DAFlys
Drone.Hunter Posted at 11-4 00:56
All drones have some slight variation,   there's no precise way to establish what height the drone is at.
2022-11-4
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. We will coordinate this to our designated team for attention. Thank you for your understanding and support.
2022-11-5
JJB*
Flight distance : 12260774 ft
Drone.Hunter Posted at 11-3 23:23
16m-17m
Hi,
Zoomed in on your flight, height performance all within limits!
See my chart of your data.
Blue height line, 'uncontrolled' changed ; red = down, yellow = up.
cheers
JJB
2022-11-5
Drone.Hunter
Kazakhstan
JJB* Posted at 11-5 02:52
Hi,
[Image]
If you strongly pull back and forth, the Drone will gradually increase the height.  I think this is due to the strong roll when starting and braking the Drone.
2022-11-6
JJB*
Drone.Hunter Posted at 11-6 09:55
Braking does not introduce a roll movement.
The software needs to calculate the revs of the 4 motors from pitch down to pitch up and vice versa.
It is 'normal' to see some height changes in this attitude change movement.
Nothing to be worried about....in you log minor height changes so best is not to look for problems when there are no problems.
cheers
JJB
2022-11-6
