Anyone found a charge + mic adapter?
804 3 2022-11-6
thothi
I've tried a few, but I could never charge and use the external mic together.
Only this worked so far:
- Connect mic only > Mic works
- Connect charger only > charging works
- Connect mic + charger > Only charging works, no mic
Did anyone find one where you can connect mic + charger to then use the mic and charge it?
Sadly will have to send the Action 3 back if that doesn't work as this is a dealbreaker for me
2022-11-6
DJI Tony
Hi, thothi. Thank you for bringing it to our attention. To further isolate the issue,  can you please confirm the connection method of connecting the external microphone and the charger at the same time? Please note that the Osmo Action 3 has only one type-C port for charging so it is not suggested to connect an external microphone and charge it simultaneously. Your kind understanding is appreciated and thank you for your continued support.
2022-11-7
Fishycomics
gonna  tear down a cable and  like I did with the Yi make one if works.   DJI won't offer the  wire diagram if asked they just say Rest assure t hank you will pass
2022-11-8
johansenfoto
Flight distance : 1173379 ft
Norway
Or use external recorder
2022-11-8
