Just a quick question. Which is a better drone, Air 2S or Mini 3?
506 6 2022-11-13
djiuser_2VATPGXLhSl2
Flight distance : 25440 ft
Im currently deciding between getting the Air 2S and the Mini 3 Pro. Which drone is better and are there any drones better than those two that cost less than €1100?
2022-11-13
DowntownRDB
Flight distance : 1722 ft
It really depends on what you are going to use the drone for and another consideration is your location.  If you are in the UK you may be better off with the Mini 3 Pro due to weight restrictions of the Air 2S.
I have both drones and both are very capable drones.  The Air 2S does have a bit larger sensor but the Mini 3 Pro is great for travel and flying time.
2022-11-13
Sean-bumble-bee
Flight distance : 15997 ft
As with the above, each has its advantages and disadvantages, there is no definitive answer that fits all circumstances and people..
2022-11-13
DJI Gamora
Hello, djiuser_2VATPGXLhSl2. Thank you for reaching out. It actually depends on what you will need. You may refer to DowntownRDB and Sean-bumble-bee's reply. Also, you can go here to compare them based on their specifications: https://www.dji.com/products/comparison-consumer-drones. Thank you for your support.
2022-11-13
Montfrooij
Flight distance : 2560453 ft
Not sure where you live, but in a lot of (EU) countries the <250g drone could be favorable.
2022-11-14
Ian in London
Flight distance : 8330187 ft
Jump to 15:38 in the video for a summary between the two!
2022-11-14
niall_h
Ian in London Posted at 11-14 03:41
https://youtu.be/oZg_GjwzMaY?t=939
thank you!
2022-11-14
