Gimbal Shake Latest Firmware in the Cold
983 4 2022-11-20
Joe Dawson
Flight distance : 1790384 ft
I have used my Mini 3 many times (over 100+) without issue but this is the first time the tempeture dropped to 0C / 32F.  And I noticed Gimbal Shake on my first flight today and yesterday in low tempetures.  Yesterday I landed and re-started and the issue cleared up.  Just wondering if anyone else has flown in below freezing tempetures with the Mini 3 Pro yet and if you have seen or not seen any issues?
Joe
2022-11-20
DJI Paladin
Flight distance : 318 ft
Can you please confirm if the aircraft does the same issue when used at normal temperature? In addition, we do not recommend flying the aircraft below 0°C to avoid this issue. Lastly, kindly please perform the gimbal calibration on your unit to ensure the stability of the gimbal when in flight. Thank you for your understanding and support.
2022-11-20
Joe Dawson
DJI Paladin Posted at 11-20 18:43
I can only comment that I have not seen this issue previously when flying in warmer weather.
I can also say that I have contacted DJI and they said the drone should fly fine in up to -10C according to the manual.
2022-11-21
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
-10 - Everything is fine, but I'm cold.
2022-11-21
Luca Rubino
Flight distance : 711512 ft
I already flew at 0-2 degrees, under a very little snow, and it worked fine. No issue
2022-11-22
