Iancraig10
Do you know of a gain control cable that works Fish?
I'm thinking that the camera has 'auto' gain so lowering it on the input side or using a mic with lower sensitivity might just cause its preamp to gain up more, causing a bit more noise. Not so noticeable on say, a motorbike, but not great for normal speech. Once the preamp in the camera is at maximum I guess then it could be controlled, but probably a lot of preamp noise.
I was wondering if the auto gain in the camera could be just backed off a bit so that it doesn't bypass zero on peaks. The better the mic, the more it shows because you get a lot more fast peaks in the audio wave form. Those are the ones, I think, that cause the peaking.
Might have to use a separate recorder, but it would be nice to be able to get clean(ish) audio into the camera.
