Does the Avata require a phone tethered to goggles to fly?
123Next >
17694 89 2022-12-9
jvhooser
Flight distance : 491155 ft
After the Avata firmware update V01.02.000, does the Avata require that a phone running the Fly app be connected by cable to the goggles in order to fly the drone because DJI did not build in RID otherwise?   Seems that a Remote ID error has appeared and the drone will not start up.  Now in addition to the battery that is tethered by cable to the goggles, is a phone required to be tethered as well just to get the drone off the ground.   I never saw this requirement prior to purchasing the Avata.
I fly indoors regularly where FAA has no jurisdiction and RID is not required, so there should be a way to disable this for these flights.
Please advise how to fly without the phone tethered.
2022-12-9
Drey. I
Flight distance : 1757375 ft
If it needs a phone that's just BS
2022-12-9
FPVTrendz
Flight distance : 1241020 ft
2022-12-9
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. To comply with the RID request of the FAA, after the new firmware, the US users need to connect the DJI Avata to DJI Fly app every time they power on the Avata to fly. It needs to be connected to App once to verify the RID, please make sure that the GPS and internet are connected. Thank you for your understanding and support.
2022-12-9
JoeJK3D
Flight distance : 618904 ft
DJI Paladin Posted at 12-9 19:16
"and Internet" ??  What? so using the avata in the middle of nowhere is not an option anymore?  Guess I am downgrading... wtf
2022-12-9
EMFant
Flight distance : 176617 ft
Just updated and you have to keep the phone tethered or nothing works. Motors won’t even start. Haven’t checked to see if the goggles battery charges your phone while connected. If not, I guess you can’t fly with a  low cell phone battery either.
2022-12-9
Newbe
Flight distance : 10693212 ft
woohoo glad I live in Australia and not the US.. started update then read this .. went, oh no.. couldn't stop update..
2022-12-9
Killerbee
Flight distance : 64820 ft
Can confirm. Non-US pilots can safely update and even use FCC hack.
We get all the goods and can fly without a phone connected to the goggles.
There's only a Remote ID warning when booting the goggles, but you can choose to skip that.
After that, it's happy flying!
2022-12-10
CTT Channel
Flight distance : 7843156 ft
Thailand
Indeed can confirm... No need to plug phone and even never saw a remote ID warning... Hope DJI will find a better solution for US pilots, I think no one would enjoy to fly with a phone connected to the goggles.
2022-12-10
FPVTrendz
So either there is an error in the firmware or this DJI rep is misinformed. Here is what that person just said above:
" It needs to be connected to App once to verify the RID, please make sure that the GPS and internet are connected."
In fact, you have to keep the phone attached to the goggles in order to take off, so it's not just connecting them once and flying.
2022-12-10
jvhooser
I was told that you have to connect to the phone , have GPS location on the phone, and the Fly app open the entire flight.
Other than this not being mentioned when the drone was released, my biggest concern is flying indoors where the phone may not get good GPS and the drone would not work according to the rep I spoke with.   Really stupid since FAA and their RID BS have no requirement indoors.
2022-12-10
Ken H
Flight distance : 822484 ft
So if your in the mountains or remote area with no cell\network connection I wont be able to fly my drone?!?.    Last update was the FAA pulled out the network requirement because of this.  Remote ID isn't even in affect for almost another year. They should fix this or offer a buy back.  I live in the north west area of USA and surround by mountains.  So now except for in town which I try to avoid, my Avata is useless.
2022-12-10
jvhooser
Ken H Posted at 12-10 11:58
As I understand internet not required, but constant GPS location on the phone is.
If you are in the mountains and phone can’t get enough GPS signal it won’t fly, even if you have internet.
I wanted it for inside construction progress pics but GPS is sketchy, so it won’t work.
2022-12-10
djiuser_zzksDeg8jWfZ
jvhooser Posted at 12-10 09:33
I’d argue it was also intentionally misleading. One of the youtube videos I watched prior to purchasing was a person flying it through a house for real estate media. This was someone dji vetted for prerelease product and I want to assume oked the footage to be shared when the embargo lifted.
2022-12-10
Ken H
This is what I have been posting to DJI Paladin and on YouTube comments.  If I am incorrect please let me know.
First, here are the facts. Last update was the FAA pulled out the network requirement and left broadcast remote ID. This should not require the Avata or any drone to have a continuous network connection.
You should not be implementing rules that are not in effect as they still may change until the effect date. FAA states it’s the pilot’s responsibility to comply by 16 September 2023 and your responsibility is make sure you build drones that are compliant after 16 September 2022.  Even building drones with remote ID should still not be activated until after 16 September 2023 at which point pilots are required to be compliant.
I am just stating facts as I found on the FAA website.  It does not state the pilot or takeoff location is to constantly broadcast. It states, “An indication of the latitude, longitude, and geometric altitude of the drone's take-off location”.  Not continuous location.  If DJI includes the takeoff location to the Drones broadcast, this meets the requirement.
Here is my complaint.  If you’re in the mountains, inside a building (which was the biggest selling point of the Avata) or remote area with no cell\network connection you won’t be able to fly your Avata!   If you are flying your Avata over water or in the mountains and your phone dies or loses cell reception what then?  Will DJI Refresh cover the loss due to this?  I live in the northwest area of the USA and surrounded by mountains.  So now except for in town which I try to avoid, my Avata is useless.  I believe this is overstepping on products purchased without these rules and your update did not state this.  DJI should fix this or offer a buy back of the Avata and any additional DJI equipment (fly more kits).
2022-12-10
SirStabbs
Flight distance : 218799 ft
For people wondering. You only need to plug the goggles until you get the RID to recognize the mobile GPS. Take off while it is plugged, then you can safely unplug from your mobile device while hovering. I tested this out and im still able to fly the Avata without limitations. i do see the "RID Error" on the goggles after unplugging it, but everything was fine on the Drone Recording.
Also, i used my ipad air 2 for the RID verification. And i DO NOT have mobile service nor wifi enabled. i simply opened the DJI Fly App, connected the Avata via Goggles 2, took off, disconnected while hovering, and everything was flying like normal. But once you land, and disarm, you will have to connect the goggles to the mobile device again to take off.
https://www.youtube.com/watch?v=lOLsg3C96dk
Here is the flight video, i unplugged the goggles at 1:38 and you'll see the "Remote ID Error" on the bottom right of the screen. But im still able to fly wihtout problems.
And i repeat My Ipad does not have  any Mobile Network nor Wifi enabled. im poor, i dont purchase the mobile plan for my ipad.
So yeah, it only needs to connect to the DJI Fly App to recognize the mobile GPS even tho its not connected to any network or internet.
2022-12-10
Axelz
Flight distance : 3427999 ft
Does this happen when you use the drone outside of the US?
2022-12-11
mark426
Flight distance : 854117 ft
Who wants to buy my brand new Avata with flymore and hardcase?
2022-12-11
fans1e84c657
This is unacceptable. No one wants an FPV drone that needs to be tethered to a phone. We should get a full refund unconditionally.
2022-12-11
BadBert
Flight distance : 59121 ft
DJI should come up with a wireless solution.....
But also: the avata is advertised for indoor flying and indoor commercial shots.... but that is a NO GO if you don't have GPS signal.......
I am glad this is not something we in the EU are affected by, but i know it is comming.... so i hope DJI will come up with a better way for this!
2022-12-11
fanscad6db0e
Flight distance : 182142 ft
Ya.. well I'm sure you've heard numerous time already, but whatever moron decided this was a good idea should be fired. Just bought mine from Adorama and will be promptly returning with my advice to them not to sell these paper weights and thank you for your support and understanding
2022-12-26
djiuser_Wf01M8yWFaTZ
Flight distance : 1276473 ft
Slovenia
So all that been said, can we undo the firmware update? I know this was possible with mini 2 after some crappy firmware updates, using DJI assistant. And maybe solution would be using fake GPS app, as it was used in Europe to boost the range of the drone by making it think it is in USA, so it enabled FCC.
2023-1-15
RichfromHowellNJ
Flight distance : 508255 ft
SirStabbs Posted at 2022-12-10 17:14
@SirStabbs - Thank you for your video link demonstrating that you are able to take off and disconnect your tablet after take off with your tablet which does not have a mobile service or WIFI enabled.  Please excuse my ignorance for asking ... but what I'm reading from other posts people who are not able to get that initial GPS signal (whether it be because they are taking off indoors or they are surrounded by mountains) will still not be be able to take off with the use the DJI Avata in the US because they can not get that initial GPS signal.  Is that still not an accurate statement?
2023-1-15
RichfromHowellNJ
RichfromHowellNJ Posted at 1-15 02:01
@SirStabbs - I did fly today after reading and watching your video.  I flew outdoors and the Avata behaved exactly as you showed.  As long as I took off connected to my cell phone with the app open .... once in the air I could fly as I normally would and land as I normally would.  Thank you for the tip!
2023-1-15
ro_walker
Brazil
2023-1-15
djiuser_LBxfzKDqg3Vz
DJI Paladin Posted at 2022-12-9 19:16
Why hasn't DJI updated their software to include the new android phones? And, it appears that this type of forum is their pathetic attempt at customer support. Theres no number you can call. I have a Galaxy S22 and the Avata Pro ended up being a $1,500 paerweight. If the fly app is required to use the drone, and DJI cant be bothered updating their software, why would anyone want to buy one. And my experience, obviously, isn't uniqe with DJI. It seems that once you've bought their product, they cease caring about wether you're able to use it.
As it stands, I will never buy another product from DJI again.
Does DJI have any plans to address its pretty much non-existant customer service?
2023-4-23
DJI Paladin
djiuser_LBxfzKDqg3Vz Posted at 4-23 06:27
Hi there. We appreciate your feedback. As mentioned above, the FAA RID required this function as DJI abide local laws and regulations. Please note that it requires you to connect the mobile device (DJI FLY App) to Goggles before flight under strong GPS signal, After taking off, you can DISCONNECT the mobile device and wear the goggles to fly. If you want an English representative, you may contact us on this number +1 818 235 0789 Monday-Sunday: 6:00 - 18:00(PST). Thank you for your understanding and support.
2023-4-24
Geo_Drone
Flight distance : 2676129 ft
Romania
DJI Paladin Posted at 4-24 03:00
DJI Paladin, the customers complain related to DJI ENFORCING a law that is NOT YET in effect.
What is not clear here?
DJI practically created a "law" without respecting user's rights and forcing an action that is not yet in effect in designated areas...
Is like I tell you that in 2023 1st December you should stay in House as COVID will be in effect !!!...And then tell you to close the door and seal it from NOW!
2023-4-27
The Saint
Flight distance : 5902228 ft
Geo_Drone Posted at 4-27 04:00
i believe these things are done in order to gain the DOC approval.  the timing isn't always the greatest but that's secondary.  i recently got the goggles integra and wires/phone/etc are no longer an issue.
2023-4-27
DJI Paladin
Thank you for your response, Geo. We will surely forward this to our designated team for attention. Thank you for your understanding and support.
2023-4-28
W3KEY
Flight distance : 482005 ft
Obviously, the first thing is that you have to update all the firmware on everything.  You can fly after you tether the DJI Goggles 2 with the phone connected with the DJI FLY app.  Once you're up in the air you can disconnect and continue flying.  But you will get that Remote ID error which is annoying.  To fly untethered with no worries at all you'll have to purchase the "Integra goggles."
2023-5-4
KREMi
Poland
W3KEY Posted at 5-4 07:51
that is sadly bullsh..
yes, integra got build in GPS, so in theory it should give You possibility to fly untethered of phone.
But as for today firmware - it does NOT work when geozoning is involved.
I got few zones where I had to get DJI permissions to fly (yes, got them from long time, got all licenses, etc). I transfer unlocks to drone when it's paired with integra+phone with internet. Should be one time action. But power cycle drone (replace battery) and it's gone. only way to start and fly is AGAIN connect phone #@!#!@# and AGAIN transfer already uploaded zones :/ and so on on every new battery :/
so integra is not giving me any advantages over older goggles and they went back.
2023-5-4
YangChaoLi
Flight distance : 691066 ft
Axelz Posted at 2022-12-11 04:50
I will tell you with my recent personal experience that it can require it at times. I don't know if that's supposed to happen but it did to me. I just returned from the Bahamas and I would say about 30% of my flights required me to tether my phone before I could take off. My phone was in Airplane mode the whole time to avoid international roaming charges so no cellular data but I did connect to Wifi from time to time. I wasn't expecting the tethering to be needed since it's outside the US but glad I brought the cables.
2023-5-4
dank13
Newbe Posted at 2022-12-9 23:06
Remote Id is coming to australia soon avata will be useless here too... specially where most of the places I fly, I have no mobile reception.
2023-7-3
djiuser_m2HyGjNjA2iH
Flight distance : 246037 ft
Drey. I Posted at 2022-12-9 09:05
I just got my Avata and I’m returning it! This is not required by law to fly a drone, especially indoors.
Other drone brands aren’t doing this ridiculousness, vote with your $$$ and STOP buying DJI products.
2023-7-12
KREMi Posted at 5-4 12:43
2023-7-12
2023-7-12
JoeJK3D Posted at 2022-12-9 20:55
2023-7-12
EMFant Posted at 2022-12-9 21:37
2023-7-12
CTT Channel Posted at 2022-12-10 03:29
2023-7-12
123Next >
