DJI Gamora
Hello, Elendil. Thank you for reaching out and we're sorry for the inconvenience. Is it just happening under 30 fps settings? You may troubleshoot with the following steps below:
1)Check if the gimbal bracket is stuck and if the rubber damper is broken.
2)Check if the propeller is misshapen or broken.
3)Check if the motor is vibrating abnormally after being started.
• If there are no issues after the above inspection, please connect to the goggles for gimbal calibration.
• If this issue is not fixed after calibration, or if the gimbal is malfunctioning due to external force, it is recommended to send back the product for inspection. You may contact DJI's Philippines Authorized Service below:
Name: Lazarus Information Technology Solutions
Phone Number:277535855
Thank you for your kind understanding and support. |
