How to use focus chart
2043 12 2022-12-21
djiuser_i3zt0NMy2j4m
India
Someone from the forum sent me this foucus chart. How i can use this focus chart to test my OA3 action camera focus is proper or not?
2022-12-21
Mr.Magic
Print the chart and place the camera in front of it (min. 0,3m). So you can see if it's out of focus. Everything should be sharp and not blurry.
2022-12-21
StevoB
Slovakia
It is best to print on A3 paper size and take pictures from a distance of 30 cm and look for when it is already sharp. Use the time self-timer for the photo, or 4k25 without stabilization, then DJI doesn't know how to make a picture from a video (grab), but it's more complicated in Davici resolve, the procedure is on yt, for example. PDF is sharper. And do it in good light.
2022-12-21
osmonauta
Hungary
And for best results, set the camera to Manual mode and use ISO 100 (for photo, that is). If it's too dark, you can adjust the shutter speed.
2022-12-21
StevoB
Slovakia
osmonauta Posted at 12-21 10:27
Exactly so, if the test is done at home under artificial, usually weaker lighting...
2022-12-21
Fishycomics
how big must he chart be , do not say 8x11
2022-12-21
StevoB
Slovakia
Fishycomics Posted at 12-21 10:33
For Hallmark007 A0 46,8 x 33,1inch to see blurry pixels around the edges of the frame
2022-12-21
Fishycomics
well we know you stand  the camera on a tripod in front a wall, and whatever the 1meter fills will be the size of the chart.
2022-12-21
India
Ok... but this is action camera seems like using DSLR canera. if this setting inage comes sharp then camera is "OK"? If we keep everything in auto mode and image comes blur then also camera is "OK"?
2022-12-21
CRAIGMART75
Flight distance : 1543901 ft
Thanks for the Info
2022-12-21
StevoB
Slovakia
djiuser_i3zt0NMy2j4m Posted at 12-21 17:39
If you want to test it, whether the focus is set correctly, you have to proceed as we describe in order to rule out motion blur and high ISO blur. This procedure applies to all photographic equipment, not just action cameras.
2022-12-21
India
Here is 100 ISO jpg image photo taken with 3 second timer so no chance that camera will move while pressing shutter button. Do you think guys this is proper sharp?I can not upload here as size problem so here is the link.
https://drive.google.com/file/d/1F69iRHlaq4LaqKmpSo0pkpoT-L8LRBL3/view?usp=sharing
2022-12-21
StevoB
Slovakia
djiuser_i3zt0NMy2j4m Posted at 12-21 22:52
According to DJI support, it is correct, they will find an excuse, either in Holland or Germany, because they probably need pressure from the UP. According to most of us, it is soft and double from 40 cm, as you have it, and not from 30 cm, as the manufacturer guarantees. You have the choice of a quick way on your own responsibility, or to stretch, because you have the right to:
Here's the Consumer Rights section in the EU.  "If goods you bought anywhere in the EU turn out to be faulty or do not look or work as advertised, the seller must repair or replace them free of charge or give you a price reduction or a full refund. You can usually only ask for a partial or full refund when it is not possible to repair or replace the goods."
I don't know for India. You can read about it in the individual threads and with the results shared by us.
Even if it doesn't look like it from my posts, I prefer to go that way if I can do it myself even at the cost of losing the warranty. If the arguing crosses a certain healthy limit when I see that the entire support is going one line stretched from the UP... I'd rather keep quiet about the answers from the support, their reactions... there's just enough bad stuff in other threads HERE MORE . I'm only writing about the problem with OA3 and camera support, I have no idea how they are doing with other technology, I believe it's fine.
2022-12-21
