How to connect Goggles 2 with Mini 3 pro?
6310 12 2022-12-24
djiuser_A4QWiteaw2eB
Czechia
Hello.
I did purchase the AVATA with Goggles 2. I did not activate AVATA. I did activate only Goggles 2. How I can connect them with Mini 3 pro?
In settings I can se onnly AVATA and not other drones.
Thank you
2022-12-24
DAFlys
The goggles aren't compatible with the Mini3 Pro.
2022-12-24
DJI Gamora
Hi, djiuser_A4QWiteaw2eB. Thank you for reaching out. Regretfully, as DAFlys mentioned, the Goggles 2 is not compatible with Mini 3 Pro. Thank you for your kind understanding and support.
2022-12-25
Czechia
What drones I can use with Goggles 2? What drones I can use if I had purchased Goggles V2? I am upsad becouse I did spend more money becouse I though I can use it for Mini 3 Pro.... Thank you
2022-12-25
Czechia
DJI Gamora Posted at 12-25 02:42
It is pity the Goggles 2 are compatible only with Avata and they are expensive. Or it will be compatible with Mini 3 Pro in the future? I am woundering why did DJI come up with new expensive Goggles what are compatible only with Avata and not other new drones. Or I am mistaken? Thank you for answer
2022-12-25
DJI Gamora
djiuser_A4QWiteaw2eB Posted at 12-25 11:34
Hi, djiuser_A4QWiteaw2eB. Thank you for the reply. I'm afraid that they won't be compatible in the future as the FPV drones (including DJI Avata) are different from the Consumer drones (including Mini 3 Pro) and those series have different development. Hoping for your kind understanding. Thank you for your support.
2022-12-31
Czechia
DJI Gamora Posted at 12-31 01:17
Thank you for your answer. I am sure it will be great from DJI and a lot of costumers will be delight if they will make an update so everybody that have Goggles V2 od Goggles 2 can be compatible with new drones. We know the Goggles 1 are compatible with Mavic series. So why do not do it again? Pls write me, are Goggles 2 compatible with FPV drone? Thank you
2022-12-31
DJI Gamora
djiuser_A4QWiteaw2eB Posted at 2022-12-31 08:19
Hi, djiuser_A4QWiteaw2eB. The DJI Goggles 2 can only be used with DJI Avata from the date of product release. It also supports DJI O3 Air Unit now. Please stay tuned to DJI’s official website for new information on the goggles’ compatibility.
2023-1-7
djiuser_1pkvPwulNqJB
Flight distance : 546585 ft
Portugal
Googles 2 and mini pro 3 . Will it be  or not....??
Should Sell it or not
. The mini pro 3
2023-3-19
KLRSKIR
Flight distance : 28368625 ft
djiuser_1pkvPwulNqJB Posted at 3-19 02:49
. The mini pro 3
If your sole reason to have the Mini 3 Pro is to use it with the Goggles 2, you'll probably be best served to sell it.
2023-3-19
djiuser_h9PllE57aO1f
Flight distance : 572963 ft
PLEASE UPDATE THIS FORUM.
GOOGLES 2 AND INTEGRA ARE NOW COMPATIBLE...
2023-5-28
KLRSKIR Posted at 3-19 05:35
good 'advice' ....
2023-5-28
Hyblos
Czechia
Hi, what is your maximum for altitude above start point? After actualisation for latest firmware, I see in Goggles 2 only 120m. How many you see in your Goggles 2 ?
2023-9-12
