DJI GO4 doesnt work on Pixel7 Pro
123Next >
13055 113 2023-1-15
igalep
Israel
Hi , recently I've switched from OP8T running Android 12 and latest ver og DJI GO4 app to Pixel7Pro running Android 13 and the same version of the DJI GO4 app (https://www.dji.com/downloads/djiapp/dji-go-4).
I canot operate my mavic 2 zoom properly.
The app launches , but I have no live view on my phone (gray screen)
I'm using the same cable I used for OP8T (working setup)
Pls advice
2023-1-15
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please try to use a different communication cable to connect your mobile device to your remote controller? Kindly please enable USB Debugging under the developer option and see if there are some changes. Please keep us posted. Thank you.
2023-1-15
igalep
Israel
DJI Paladin Posted at 1-15 04:01
Nope , it's simply doesnt work
Not sure if the problem related to Android 13 or Pixel 7 pro device
Any plans on dji side to implement a computability between these two ?
2023-1-15
DJI Paladin
igalep Posted at 1-15 11:42
Thank you for your response. We highly recommend using a recommended mobile device that shows on our website as it shows that the mobile device that you mentioned is not listed on our recommended mobile device and this might be the reason for the issue. You may refer to the link below to check the list. Thank you for your understanding and support.
2023-1-16
igalep
Israel
Really , since when pixel devices are not compatible ??
2023-1-16
igalep Posted at 1-16 04:59
Hi there, we are sorry for any inconvenience. Since the said device is not on the compatible list, the performance is not guaranteed. But we will do our best to help. May I ask if there is any error message on the app? Please provide us with a screenshot to check.
2023-1-17
catarsan
I have the same problem I contacted them since the google pixel 7 release and DJI support said that they were working on...after more than 4 months still not working and DJI DO NOT CARE! They sell the drones and no support after!
2023-2-12
catarsan Posted at 2-12 02:39
Hi there, we are sorry for any inconvenience caused. May I ask if you've downloaded and installed the latest DJI Go 4 version? You can download it through this link. https://www.dji.com/downloads/djiapp/dji-go-4
2023-2-13
Raverty
I'm having the same issue. Most updated version of the app. Everything seems to work fine, the app opens and connects to the mavic 2 but the video connection is pretty much frozen. It will sometimes move/update but then goes back to frozen black and white image. I'm using a pixel 7 pro.
2023-3-24
DJI Wanda
Raverty Posted at 3-24 09:26
Thank you for your feedback.
We are sorry that this mobile device is not on our compatibility list currently. We will recommend you use other compatible mobile devices first.
For your issue, would you please provide some information for us?
We will forward it to our engineers.
1. Screenshot of mobile device system version;
2. A video with the malfunction phenomenon recorded;
3. App log;
4. Time when the issue occurred in the last few times
2023-3-24
igalep
Israel
DJI Wanda Posted at 3-24 20:12
It's a total shame that Google's flag ship device is not supported by dji
2023-3-24
ilpaolino1
Flight distance : 16047 ft
Same problem here. Bought a new Pixel 6a and i should get rid of my Mavic 2?
2023-3-25
DJI Wanda
igalep Posted at 3-24 23:16
As we explained, this mobile device is not on the compatible list, which means we did not test the mobile device before and therefore, the performance is not guaranteed.
It would be appreciated if you can provide us with some information so that we can escalate your issue to our engineers for evaluation.
The compatibility list will be updated once our engineers complete compatibility tests on new mobile devices.
2023-3-25
postas
Armenia
Same thing. Pixel 7 (not pro), Android 13. Latest version of the app. Live view frozen most of the time.
2023-3-25
DJI Susan
postas Posted at 3-25 12:26
Sorry for the inconvenience. Our engineers are still working on the compatibility of Google Pixel 7 series with DJI GO 4 app.
If you have an urgent flight mission, we recommend you prepare a spare mobile device to carry out the mission, instead of using this device to avoid the mission cannot be carried out due to compatibility issues.
We are sorry again for the inconvenience caused to you. Thank you for your understanding and support.
2023-3-25
Salazar_S
I've had this same problem for months now. What is being done to fix this? A flagship device should have support.
2023-4-6
Salazar_S Posted at 4-6 22:53
We are sorry for the inconvenience. Our engineers are still working on the compatibility of the Google Pixel 7 series with the DJI GO 4 app. If you have an urgent flight mission, we recommend you use another mobile device to fly. We will also forward your feedback to the corresponding team. Thanks for your understanding.
2023-4-7
patiam
Flight distance : 1118740 ft
Add me to the list. Flagship, current model top-of-the-line Android phone (Pixel 7 pro). And DJI Go 4 won't run on it.
2023-4-18
JonteG
Sweden
Add me to the list. Latest version of DJI 4 go and Pixel 7 pro and problem.
2023-4-19
evilsquirrel_15
Add me to the list as well. Pixel 7 (Non Pro). DJI 4 go
2023-4-19
patiam Posted at 4-18 10:11
Hi there, we are sorry for any inconvenience. As we replied above, our engineers are still working on the compatibility of the Google Pixel 7 series with the DJI GO 4 app. If you have an urgent flight mission, we recommend you use another mobile device to fly. We will also forward your feedback to the corresponding team. Thanks for your understanding.
2023-4-19
JonteG Posted at 4-19 08:52
Hi there, we are sorry for the inconvenience. You may refer to our reply on 21#
2023-4-19
evilsquirrel_15 Posted at 4-19 17:13
2023-4-19
evilsquirrel_15
Any updates on this???
2023-4-28
djiuser_QwLTkA5F1Ld2
Flight distance : 1593586 ft
Pixel 7 Pro and newest DJI Go 4. Same problem as everyone before me. PLEASE FIX IT!
This is an embarrassing service for a product this expensive!
2023-5-3
DJI Wanda
djiuser_QwLTkA5F1Ld2 Posted at 5-3 08:44
Hi there, we are sorry for the inconvenience. You may refer to our reply to DJI Mindy's reply at 21#.
You may refer to the official website for later updates.
2023-5-4
DJI Wanda
evilsquirrel_15 Posted at 4-28 18:13
Hello, there. Currently, we have not received information. You may refer to the official website for later updates. Thank you for your support and understanding.
2023-5-4
VanHell
Flight distance : 7326 ft
May 2023 and DJI has no fix for Android flagship Pixel 7 (Pro) and DJI Apps.
Need more informationen? Just try to install and work with any DJI App on a Google Pixel 7 (Pro)
The problem is not that we don't look at your website for latest updates... the problem is, that DJI don't care for users who uses Android devices (iPhones all supported).
DJI shouldn't advise its customers to use alternative cell phones, but maybe just create an app for an Android flagship.
And no, we don't understand, we are angry at DJI.
This is not a inconvenience, it's a catastrophe!
2023-5-7
VanHell Posted at 5-7 09:35
Hi there, we are sorry for the inconvenience. Our engineers are still working on the compatibility of the Google Pixel 7 series with the DJI GO 4 app. If you have an urgent flight mission, we recommend you use another mobile device to fly. We will also forward your feedback to the corresponding team. Thanks for your understanding.
2023-5-8
haidonism
Hi Dji team, I'm also experiencing the same issue whereby I've also got the Pixel 7 Pro and unfortunately experiencing the same issue with the DJI Mavic 2 Zoom. Happy to share any data needed by the engineering team that may help resolve this ongoing issue.
thanks
2023-5-14
haidonism Posted at 5-14 04:58
thanks
If you're willing to provide us with the app log, you can follow the steps below to export the log and we will forward it to our engineer for further checking.
1. Connect the Android device to a computer. Tap “Transfer files” in the “USB connection mode” appeared on the mobile phone.
2. Click the mobile phone icon in “My Computer” and go to internal storage.
3. Find the file path for logs: \DJI\dji.go.v4\LOG
4. Copy and paste the entire “LOG” file folder to the local drive and add the file folder to the compressed folder. Upload the log to Dropbox or Google Drive and then send us the download link here.
2023-5-14
Ichi.Dosei
Hello Dji team! There are updates??? I also report that I have a problem with the live video signal, receiving a lost video signal error and a gray screen when turned on with the drone stationary on the ground. I have the latest version of the dji go 4 app and the updated pixel 7 pro. Tried different cables but the problem persists.
2023-5-18
DJI Wanda
Ichi.Dosei Posted at 5-18 03:09
Hello, there. Sorry for the inconvenience. May we know did you report the issue to our email support or online chat support? Have you received the response?
2023-5-19
Gusthebaker
Flight distance : 2707 ft
Same issue here, and it's troubling that when reaching out to the support team not on this forum they don't even know it's an issue, so I ahve been doing tests, bought new cables, for absolutely nothing,
And it's still not working at the video signal is lost , I can't see anythign when flying, and the drone wants to come home because of the signal being lost.
2023-5-25
DJI Wanda
Gusthebaker Posted at 5-25 10:48
Hello, there. Sorry for the inconvenience. May we know whether the issue is no live feed in your phone or the signal loss?
2023-5-26
Gusthebaker
DJI Wanda Posted at 5-26 01:01
Just as I wrote. The video pauses, is black and white, then the app seeing the video is lost wants to bring the drone back.
2023-6-3
DJI Susan
Gusthebaker Posted at 6-3 15:55
According to your description, it sounds like the issue is the connection between the controller and aircraft is lost, it is not related to the connection between the controller and mobile device.
Therefore, please first make sure that you have updated the firmware for both the drone and RC, then try to relink the drone and RC. Please fly in different locations to see if it could be the interference of the specific location.
If the drone will disconnect to the controller at a short distance very frequently, you are recommended to send the drone back for further analysis.
Thank you for your understanding.
2023-6-3
Gusthebaker
It s not the drone not connecting , it s the video feed being poor, just like other users on this thread. It was working fine till I upgraded my phone.
2023-6-4
evilsquirrel_15
I don't think this will ever get fixed, sad
2023-6-4
DJI Wanda
Gusthebaker Posted at 6-4 08:02
As DJI Susan explained, the video loss is due to the disconnection between the aircraft and the remote controller. The error message "Image transmission lost" also indicated that and that's why the live feed will be black and white because the transmission was cut.
2023-6-4
123Next >
