Charging
638 9 2023-1-16
Roylpain
First Post... Can I video and charge at the same time?
Thanks,
2023-1-16
DJI Gamora
Hi, Roylpain. Thank you for reaching out and for joining DJI Forum. Yes, you can. However, it is recommended to use the Osmo Pocket after it is fully charged. If you use the Osmo Pocket while it's being charged, the battery will generate heat, which shortens the battery life. Hope this helps. Thank you for your support.
2023-1-16
Roylpain
DJI Gamora Posted at 1-16 22:09
Thank you for your support!  One last query on this subject and I'll be good to go...
So is a regular usb/AC adapter into in wall circuit ok?
2023-1-16
Blériot53
Flight distance : 6260935 ft
Roylpain Posted at 1-16 23:48
So is a regular usb/AC adapter into in wall circuit is ok?
That's what I use. Or you can even charge it from a USB port on your laptop. I do that too.
2023-1-16
Roylpain
Blériot53 Posted at 1-16 23:57
Much thanks!
2023-1-17
Blériot53
You're welcome
2023-1-17
HGDC84
Finland
If I remember right, they officially suggest that if you need to charge the Osmo Pocket while filming, then it is advised to use a powerbank instead of AC power. I myself have a 20,000mAh Anker PowerCore with a trickle charge function and it has served me well for this purpose. (I myself use a Pocket 2 though, so YMMV.)
2023-1-17
Roylpain
HGDC84 Posted at 1-17 16:03
Thanks for this since I was planning of using the AC connection tonight. I think I'll wait until I'm sure I won't damage my camera.
2023-1-17
DJI Gamora
Hi, Roylpain. You're most welcome! That will be fine but as mentioned above battery will shorten battery life if you use the Osmo Pocket while charging. Thank you for your kind understanding.
2023-1-18
HGDC84
Finland
Roylpain Posted at 1-17 17:15
No problem, I hope you find the best way to use your camera, considering both functionality and the lifespan of the camera. :-)
2023-1-18
