DJI Remote control no longer connecting to OnePlus 8 Pro
3468 14 2023-1-17
docwhiskey
Flight distance : 2631598 ft
Jersey
I have previously been able to control my DJI mini 2 with the remote and my OnePlus 8 Pro - however since a software update, when I open the app it is unable to connect to the remote.
2023-1-17
DJI Gamora
Hi, docwhiskey. Thank you for reaching out. Sorry to read that you're not able to connect your phone to the RC after the update. Kindly follow the troubleshooting steps below:
1. Please confirm if you have a protective case covering your mobile phone. If so, remove it and try connecting again.
2. Disconnect and reconnect the USB cable (from both the mobile phone and the remote controller), waiting 10 seconds before reconnecting the USB cable. If possible, retry with another USB cable.
① Please make sure that the cable is connected to the correct port (need to use the connection port for the phone's connection) as the picture showed:
② Please plug one end of the cable in normally and upside or further checking.
3. Restart the remote controller.
4. When using an Android device, if there is a prompt, be sure to tap [OK].
When DJI Fly is being used, USB Debugging must be enabled in the mobile phone system.
Enabling “USB Debugging” with an Android device. Please follow the steps below:
1. Go to [System Settings] > [About Mobile Phone].
2. Tap “Version Number” quickly 7 to 10 times (If the mobile phone has a screen-lock password, please input the correct password in accordance with the system instructions) until the mobile phone displays: “You’re in developer mode!”
3. Search for “Development” in the [System Settings].
4. Go to [Developer Options];
5. Slide the view up and down on the page until you see the “USB Debugging” option.
6. If the issue persists please try another device and try to switch to a device with a different operating system (Android <--> iOS).
Hope this helps. Please keep us posted. Thank you for your valued support.
2023-1-17
docwhiskey
Jersey
DJI Gamora Posted at 1-17 20:10
Hi, thanks for the suggestions. I have tried all of these, as found similar suggestions on other posts. However, it still doesn't work on my phone. It does, on the other hand, work with an iPhone - so it's very likely to be that the controller is no longer compatible with OnePlus 8 pro - which is really frustrating and something that DJI may look into? I'd rather a solution that avoids me having to buy a second phone to use my drone
2023-1-18
DJI Gamora
docwhiskey Posted at 1-18 07:08
Hi, docwhiskey. We understand where your coming from. I will forward this concern to our relevant team for further checking. I'll update you once I receive feedback. Thank you for your kind understanding.
2023-1-21
DJI Gamora
Hi, docwhiskey. We have sent you a PM, kindly check. Thank you.
2023-1-25
docwhiskey
Jersey
DJI Gamora Posted at 1-25 05:14
Hi, how do I see PMs?
2023-1-25
DJI Gamora
docwhiskey Posted at 1-25 05:20
Hi, docwhiskey. You may click the Personal Message icon under my Profile on this post or you may also check the notification bell on the top right side, you should be able to see Messages under it. Please see the images below for your reference. Thank you.
2023-1-28
djiuser_cDlbNz5TbDl6
Flight distance : 47877 ft
Singapore
This is quite a concern. I have a Oneplus 10 pro phone and it was fine connecting with the remote controller until that app update. I regret updating the app version.
Now I cannot connect to the remote at all.
DJI, please help an add ALL oneplus ohone to ur list. Both of you are Chinese companies and should be compatible with one another.
Frustrating that I cannot use the drone for my trip next week.
2023-5-26
djiuser_tcVIYIh9FKzj
Was there ever a solution found for this? I just purchased a DJI mini 2 and when I tried to connect it to my OnePlus 8 Pro, it won't work
Any solution??
2023-8-14
djiuser_DcoAxgXr2SGI
How come the OnePlus 7 pro isn't compatible with the controllers.  My phone runs on Android 10so I don't get it why this is super frustrating that I would have to buy a second phone just to be able to fly my drone around properly
2023-8-25
Andreas Kleeberger
Austria
Same Problem with my new DJI Neo, the RC-N3 doesnt work with the oneplus 8 pro. Very sad u prefer iOS peoples. Thats the reason i have to return my Drone and never go back to dji. Bad Support for usual mobiles.
2024-9-12
djiuser_OVCfhKYAl5yv
Portugal
Andreas Kleeberger Posted at 9-12 06:07
Same here: RC-N3 does not connect to my OnePlus 8 pro.
2024-9-15
djiuser_yFHxIgjIkynP
Hi DJI
Still no solution? No answer?
I bought a Neo FMC. And the RC isn't useable with OnePlus 8 Pro.
What to do? Send back?
2024-10-27
Capifly8
Flight distance : 21291634 ft
Chile
I have problems with the Mavic 3 and a OnePlus 8 phone, DJI FLY V1.15.8 1075-official. The remote control does not connect to the cell phone, therefore there is no connection with the drone... Do you have a patch available?
2024-12-20
tjezic
Croatia
@DJI Gamora, we have the same issue like many other users, remote control does not connect to the cell phone, therefore there is no connection with the drone.
USB Debugging is enabled in the mobile phone system, and we tried every step as mentioned earlier but with out success.
Are there any solution for fixing connectivity of DJI remote controller RC-N3 RC-151 with One pluse 8 mobile phone ?!
Remote was bought on 15.12.2024, with Neo drone, and ONE Plus 8 PRO is :
Build number : IN2023_13 1.0.590(EX01)
Baseband version : Q_V1_P14,Q_V1_P14
Kernel version : 4.19.157-perf+
Android version : 13
Android security update : 5. June 2024
DJI FLY application is up-to-date (v1.15.8.(1075-official)
1-8 05:48
