DJI Mavic 2S Mapping Capabilities
2558 5 2023-1-27
fans0d38a7cf
Hello all,
I recently purchased a DJI Mavic Air 2S and using a WebODM and Dronelink setup.
I own a GIS business, and have a commercial ESRI license (view georeference outputs - orthos etc)
What process is used to generate a topo with contour lines?  I am mapping a golf course in the mountains and working toward outputs used in the commercial space and video for promotions.
Any advice is greatly appreciated.
Regards,
Chris
2023-1-27
LV_Forestry
Flight distance : 4726654 ft
Latvia
Hi,
Place drone pictures in a photogrametry software. Then generate point cloud. Classify ground point and generate DTM. Use your GIS to generate raster with contour.
2023-1-27
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for bringing this query to us. The DJI Air 2S does not support the surveying and mapping function, the main reason for this is that the surveying and mapping function has high requirements for the aircraft positioning system and camera lens. Currently, DJI Mavic series drones cannot support such professional functions. You may want to check our DJI Enterprise products (such as Matrice 300 RTK/ Phantom 4 RTL). Thank you for your understanding and support.
2023-1-27
LV_Forestry
Latvia
DJI Paladin Posted at 1-27 19:50
GCPs.......
2023-1-27
djiuser_9vVVsQukETYQ
Flight distance : 251273 ft
LV_Forestry Posted at 2023-1-27 07:39
Hi,
data that a rtk survey would provide would have tolerances within a tenth. would doing all that be that tight? i cant imagine it would if your running grs of anykind ive seen ... meters away from where it was supposed to be. idk
3-15 08:45
LV_Forestry
Latvia
djiuser_9vVVsQukETYQ Posted at 3-15 08:45
Everything is relative, distance from the base station, lens calibration...
3-15 09:16
