DJI Goggles v2 battery not charging, turning on
2224 3 2023-2-11
djiuser_2YkQnde6oPtj
Flight distance : 368074 ft
I've had my dji fpv drone since last june, and in october got an avata and have been using the v2 goggles and the same battery for both.  The battery worked fine until a few days ago, but now it won't turn on or light up when you press the button. Plug it into a charger and it rapidly lights up in sequence like it's charging, but still won't turn on when you unplug it even if its connected to the goggles.  Any ideas?
2023-2-11
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to leave the battery on the charger for approximately 2-3 hours and check if the issue persists? Please make sure to plug in the USB cable all the way through till you hear a "click" then try to turn it on to see if there are any changes. If the issue persists, please provide us with a short video showing the issue for us to check. Please keep us posted. Thank you.
2023-2-11
Reuben Pillay
Flight distance : 91480450 ft
Mauritius
DJI Paladin Posted at 2023-2-11 20:12
Hello,
I'm having the same issue - I've uploaded a video to my drive to demonstrate it:
https://drive.google.com/file/d/ ... Hy/view?usp=sharing
(please download to view if it's not readily viewable from my drive)
Kindly advise.
Thanks,
Reuben
3-6 18:09
DJI Paladin
Reuben Pillay Posted at 3-6 18:09
Hello,
Hello there, Reuben. We do apologize for the inconvenience caused. Based on the video that you provided, if your battery is still within the warranty period, you may contact our team at https://www.dji.com/support to process a ticket case or contact the dealer where you purchased the unit to ask for their after-sales policy. If the battery is already past its warranty period, I'm afraid that you need to purchase a new battery as we cannot process a battery replacement for a product that is no longer under warranty. Thank you for your understanding and support.
3-9 00:11
