GT2022
DJI Paladin Posted at 2-11 19:34
Hi there. Thank you for reaching out and we do apologize for the inconvenience. The DJI Mini 2 aircraft does not have a built-in fan. After it is powered on for a period of time on the ground, this overheating error is triggered in the app. Please power off the aircraft and let it stand still for a period of time. This prompt will disappear after it cools down. During a normal flight, the "Aircraft Overheated" warning will not be triggered. Hope this helps. Thank you for your valued support.
No Paladin, no inconvenience experienced. You see there was no overheating warning raised but rather I was just a little concerned that when I'd finished checking for firmware and had no intention of flying that when I shutdown and picked up the unit it was quite hot. However, as fellow pilots have mentioned in this thread, it appears to be quite normal. I like the suggestion to blow a fan on the unit for any extended on-ground operation and that's something I will keep in mind going forward. Thanks. |
