Flashing green LED, no calibration OM3
536 5 2023-3-8
Machiavellis
Poland
Hello.
I own an Osmo Mobile 3 and have used it very rarely.
Recently when I turned it on it slowly flashes the green LED and the gimbal does not hold position. Literally nothing from the online tutorials works. Re-installing the software on the phone doesn't help either. Several attempts to disconnect and reconnect don't work either. The device has not fallen or been damaged anywhere.
When I try to do the calibration in the options it does not respond when I click start. Is there any way to completely reset the device?
2023-3-8
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please confirm what mobile device are you currently using on your DJI Osmo Mobile 3? Can you please provide us a short video showing the issue for us to check? Please keep us posted. Thank you.
2023-3-8
Machiavellis
Poland
Hi.
I have used and continue to use a Xiaomi Redmi Note 8 Pro phone.
The problem with connecting the device to the phone.
The device does not hold position, it only responds to the trigger.
Sometimes strange things happen, because it seems that the device is connected to the phone, because it jumps the screen to the camera view, but does not respond to the button to take a picture or shows an empty battery, even though it is fully charged.
https://www.youtube.com/shorts/V7iKocIlIvE
2023-3-9
Hi there, please try to follow the tutorial below to balance the gimbal again to see if the issue still exists.
2023-3-10
Machiavellis
Poland
Hi.
Each time I perform these steps before starting the device.
Unfortunately, the OM still does not work properly.
What could be the cause? Why is the green light flashing?
The device practically does not do its job.
In my earlier post is a short from the current state of the device.
2023-3-10
In this case, we recommend you submit a case through the link below and send it back for further diagnosis. http://www.dji.com/support As for the system status LED, you can refer to the picture below or the user manual: https://dl.djicdn.com/downloads/ ... _Manual_v1.0_en.pdf
2023-3-11
