Low level audio on new action 3
3269 27 2023-3-10
grumpygit88
Flight distance : 443202 ft
I have just bought an Action 3 to replace an old ailing action camera, but I'm finding the audio level is really low using the internal mics and I can't get any of my external mics to work with a 3.5mm to usb-c adapter.
I'm not getting any help from DJI support to see if I can fix this and I need the camera to at least get enough audio to sync with my main camera feeds at a wedding next week - so no time to get a replacement from Amazon if there is no fix forthcoming. Latest firmware was installed when I set the camera up, so that is all up to date.
Has anybody got any suggestions? I thought there was supposed to be a gain control, but this may only apply to external mics? No information in the manual.
Thanks
2023-3-10
DJI Wanda
Hello, there. Sorry for the late response. May we know if you contacted our support before about this question?  May we know what external mics did you try?
2023-3-10
johansenfoto
Flight distance : 1173379 ft
Norway
What kind of usb-c adapter are you using? Do you use TRRS mic on TRS adapter?
2023-3-10
Fishycomics
Correct the external mic must be plugged in. to access a gain control,  default of the camera is Omni Directional, no  wind on automatic all mics. with Pr chosen  the mic can be enabled for stereo, mono, wind,  front .  post a sample up be at 3 feet and you get the sound recorded the camera will pick up any noise
2023-3-10
grumpygit88
DJI Wanda Posted at 3-10 07:05
Yes, I contacted support yesterday and was told I would get a reply by the end of the day. I tried both Rode Stereo Video mic and Takstar mono video mic, both with TRS 3.5mm plugs, I don't know if the adapter has a TRS or TRRS socket, but I'm assuming TRS? It's the only adapter I have to hand. Thanks.
2023-3-10
Fishycomics
People use today most Smartphone adapters, careful on that. its a camera TRS.  so if you are using a usb type to to 3.5mm that be the right choices google a photo on TRS and trrs
2023-3-10
lutzmix
look also here
https://forum.dji.com/thread-280749-1-1.html
2023-3-10
grumpygit88
Thanks for all your replies, I will look at my best option. I don't want to spend a lot of money until I can be sure the audio circuits in the camera are okay, I'm still not sure. I still have very quiet audio on the internal mics... except for very loud wind noise, which is disappointing as wind noise reduction was on; I was prepared to accept wind noise as inevitable, but given that there was almost no wind this afternoon and the camera was static on a tripod, and given the fact it doesn't pick up wanted sounds very well... not very impressed so far
Thanks again for all your help.
2023-3-10
johansenfoto
Norway
grumpygit88 Posted at 3-10 10:58
Often people tend to use an usb-c adapter ment for headphones (android phones) so then mic will not work.
There are a few adapters that we know work, BOYA BY K4 is one of them.
Internal mics are not really good when there is wind, and we still haven't found a easy solution to block the wind. I need to try with some foam or something.
2023-3-10
DJI Wanda
grumpygit88 Posted at 3-10 08:25
Got it. We saw that our support is still waiting for the update from our engineers. Would you please also confirm what type of your eternal mic is so that we can offer you a complete solution?
1) 3.5mm microphone (wireless/wired);
2) USB-C microphone;
3) USB-C headphone with mic;
4) 3.5mm headphone (SRRC/SRC)
Thank you in advance.
2023-3-11
grumpygit88
DJI Wanda Posted at 3-11 00:24
Thanks, can you forget about the external mic for now, I'm fairly sure that is a cable issue?
I'm more concerned that internal mic doesn't capture audio very well. I would expect it to be able to capture normal speech from a distance of 1 metre indoors with no wind at a reasonable level. I don't want to have  to rig an external mic every time I need to capture ambient sound, it defeats the purpose of having a compact action camera.
Outdoors, the so-called wind noise suppression is non-existent. There is no point in having the so-called 'windproof' mic underneath, it's useless - I couldn't imagine mounting this on a moving vehicle.
If there is no solution to this, it is going back to Amazon on Monday as faulty/not fit for purpose and I will buy a GoPro instead. I have a £20 SJCAM SJ4000 that has better audio recording than this.
2023-3-11
DJ DJ
grumpygit88 Posted at 3-11 01:04
Hard to tell without an example shot. From what you describe, I consider that a hardware fault. From 1m in a quiet room, I get the clear and loud audio I expect, comparable to any other cam or phone so far.
If you have a look at the many examples on youtube, you see, how the Action 3 should perform. If yours differs from that, it may be defective.
2023-3-11
DJI Wanda
Understand. We will report the updates once we get a response from our engineers.
If you have any questions later, please feel free to talk.
2023-3-11
Fishycomics
Do not  wait for that DJI update go return your Unit,   the Chip mics are under a membrane and that also puts a slight dampner of getting round  to you. but  the camera sound  not to meet your expectations, and  all we have is your word, and that we will accept
the camera SUCKS at  outside  in cameras view with internal Audio.
2023-3-11
Rocktheasphalt
Maybe this will help you: The mic at the bottom is used to lower the wind noise (but you will notice a reduction overall wenn you blow on it and speek emmediately afterwards). This will only happen if there is to much wind noise and only if noise reduction is on. Switching noise reduction of and changing the settings to front mic could help you, picking up the sound from 1m in front of the camera. Adding a windscreen to front mics would improve the result even further.
Another way to solve the problem could be: Switching noise canceling on, but covering the bottom mic with some sort of foam to decrease the amount of overall volume reduction.
I guess DJI has some work to do here also... the good thing, it can be done in firmware updates!
2023-3-11
Fishycomics
wind noise is no wher like a gopro if asked
2023-3-12
Fishycomics
this is part of my vlog.
wind noise on, forced to use Pro, how the camera sounds with small wind
2023-3-13
grumpygit88
Fishycomics Posted at 3-13 03:10
Apart from the wind, your audio is great. Compare how low level the audio is on mine...
2023-3-13
Fishycomics
Here I demonstrate how the camera should sound like to all. talk low, medium loud, and a external mic. since DJI controls audio of default we must go into the PRO, and that is not what I want to do but gopro is about the same with  protunes.  can a camera company just offer audio separately to Control at default, no
2023-3-13
grumpygit88
Fishycomics Posted at 3-13 04:15
Thanks, that's really helpful. Maybe just need to speak louder
Unfortunately,  I can't control that in this case, I just want to place the camera as a discrete wide angle view during a wedding ceremony and capture enough audio to sync with the two main DSLR cameras which have good external mics for the finished audio. Worst case scenario, I will just have to sync the wide  views manually and think about getting another external mic. Just wish they could add manual gain for the internal mics.
Thanks
2023-3-13
Fishycomics
in a room of many people, you did this before, then you really know the answer this is not going to be the camera audio for it, use  sound recorder, and synch up , simple snap of  finger or  hand clap or a phone app  clapperboard.
years ago kodak zi8 has an internal audio gain,  doubt we see DJI ever adding that in, they only have an external audio gain
wish the best my friend on  the wedding  video, there is a member in here  that  may have done what you were asking and had flicker, issues,  have to look for the thread
2023-3-13
grumpygit88
Fishycomics Posted at 3-13 08:29
Thanks, sure I can do that, but to be honest, if I have to, the camera is not fit for purpose.
I just got off the phone to Amazon, the camera is going back for refund. Not only is the sound bad but during a side-by-side comparison test, the picture on my 2015 £30 1080p SJCAM4000 is actually sharper than the 4K picture on the Action 3. I thought they were supposed to have fixed the focus issues.
It's a shame because all my other DJI kit works so well.
2023-3-13
Fishycomics
grumpygit88 Posted at 3-13 08:44
you want a sharp picture from a Super-wide  camera, nope not gonna be happening     you had to talk to a different person at Amazon, I bet,   Gopro may be a little better but remember it anAction camera more control over the lesser expensive ones like this and Insta. maybe Insta 360 One RS and Johanson in here has.   hope you find hte product you are after.
For me I did not lose out or care for being sharp at 20 cm
2023-3-13
hurtighansen1
Flight distance : 26296 ft
Denmark
Do not buy boya k4 trs. It sucks. Just saying. The best is an trs usb mic or adabtor, but until we know witch works, save some $. Im using, Apple usb c trrs +Ulanzi Arimic 1.5M/6M Clip-on Lavalier, low price, and it works. im using gain +5db on oa3 with this. But, if, we find perfekt working usb c trs, use that one. But, it will cost $ lol.
2023-3-13
djiuser_aglCDVhxomRm
Have you been into the settings, dragging down from top, there is a sound control which can be set from low to high.  Don’t know if this will help.
2023-8-28
lutzmix
Samsung usbc- trrs adapter
Smallrig wave l1  mic
camera gain -2db
here with BoyaK04 trs adapter
the noise is traffic noise from the street
you can use the Smallrig lav mic with the DJI mic
Best price ca
Samsung adapter  2,50€
Boya k-04. 15€
Smallrig wave L1. 10€
2023-8-31
lutzmix
andoer lav mic with 90cm telesin selfie stick
samsung trrs adapter
andoer lav mic ca 5€
intern camera gain -2db
I think  andoer and smallrig are similar
2023-9-1
djiuser_8VcKAhssU8GW
Dji Action 4, Mono/-6 gain
Saramonic sr-c2003 adapter
Sennheiser ME 2 lav mic, yes the locking 3.5 works with the non locking adapter.
Using this for Motovlogging, minus having to boost the audio levels in post. The audio is the cleanest I have ever had it from DJI, Gopro or insta360
2023-9-4
