Using Gimbal Dial to raise and lower drone
354 11 2023-3-20
Tagarnav
Argentina
Hey guys, I own a DJI Mini 2 Pro, I was wondering if there's a way to change the controls so I can use the Gimbal Dial (preset is used to aim camera up and down) to lower and raise my drone. I tried the defaul control setup that comes with DJI Fly, and I'm not a huge fan of it, also changed it so all of my horizontal movement is done with my left stick, and my vertical and rotation movement goes on my right stick.
I basically wanted a similar setup, but have the right stick control the "camera movement" just like any FPS game, so I can rotate the camera in all directions with my right stick (rotate drone and control gimbal) and move the vertical movement of my drone to the Gimbal Dial.
Is there a way to acchieve this? Thanks!
2023-3-20
Prezzodrone
Flight distance : 8533 ft
I only have the standard Mini 2 but theres no option for that.
2023-3-20
Tagarnav
Argentina
Prezzodrone Posted at 3-20 10:41
Maybe another app that would unlock those control options?
2023-3-20
Prezzodrone
Tagarnav Posted at 3-20 10:42
I doubt it
2023-3-20
DowntownRDB
Flight distance : 1722 ft
The software is written so you can choose stick mode 1, 2 or 3.  I don't think any will let you raise and lower drone using the gimbal dial.
2023-3-20
Tagarnav
Argentina
DowntownRDB Posted at 3-20 12:55
You can customize the 2 sticks with any functionality, but not the Gimbal Dial which is locked on the camera gimbal movement, that's not even exposed on the settings.
2023-3-20
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Currently, we don't have this feature available on the said unit due to hardware limitations. However, I will take this as a suggestion of yours and will forward it to our designated team for attention. After the evaluation of the engineers, significant suggestions or requests will be implemented via the firmware update, app update, etc. For any updates, please stay tuned to the latest news on our DJI official website at www.dji.com. Thank you for your valued support.
2023-3-20
DowntownRDB
Tagarnav Posted at 3-20 13:30
That's because that feature is not currently available.
2023-3-21
Jake. A
Flight distance : 1205715 ft
I would stick to the normal controls if i were you.
2023-3-21
Tagarnav
Argentina
DJI Paladin Posted at 3-20 20:56
That'll be great, I hope it helps improve the experience. Thanks!
2023-3-21
Tagarnav
Argentina
Jake. A Posted at 3-21 07:42
Looks like I have no other option lol, that's what I'm doing now, just wanted to ask if this was possible, it doesn't seems too far fetch and tbh it makes sense for anyone used to using controllers and related to gaming too, EVERY game uses what I'm trying to achieve as camera movement, so having this option would be very beneficial for newbies too.
2023-3-21
DJI Paladin
Tagarnav Posted at 3-21 07:53
You are most welcome. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
2023-3-23
