Faulty Battery
1132 5 2015-8-24
craig
Flight distance : 12123 ft
Just charged a brand new battery and I found it flashing twice at LED3. Manual says to "press the button to turn off the Battery Level Indicator. Unplug the Intelligent Flight Battery from the charger and plug it back in to resume charging." But for kicks I popped it in and checked the app. Any advice? Never even flown the battery.
2015-8-24
Christian
Hi Craig, this doesn´t look good. The max. difference of each cell should be 0.2v and there are several cells at this battery which are way beyond.
Talk to your dealer or DJI for a replacement. I would not fly this battery at all.
Cheers, Christian
2015-8-24
Skywolf007
Flight distance : 2758875 ft
Slovakia
I would try to deplete the battery under 5% and format it - maybe the electronics needs recalibration. Does the app showing any errors?? If it wont work, return it to your dealer.
2015-8-24
joeyjoe
Skywolf007 Posted at 2015-8-24 22:43
I would try to deplete the battery under 5% and format it - maybe the electronics needs recalibratio ...
Hi, for my own knowledge, can you explain "format it" please?
Thanks.
2015-8-25
Skywolf007
Slovakia
joeyjoe Posted at 2015-8-26 03:43
Thanks.
Deplete the battery under 5% or until it can't be turned on. Charge the battery. That's it
2015-8-26
mtnmaddman
Cycle battery as suggested you may also want to look at this http://forum.dji.com/thread-23697-1-1.html
2015-8-26
