How to create a HDR Panorama
2226 23 2023-4-26
Montfrooij
Flight distance : 2560453 ft
I have been tweaking my HDR panorama workflow and made it quite efficient. It is still some post processing, but not too bad.
2023-4-26
Blériot53
Flight distance : 6188465 ft
I'll watch in the morning when I'm more alert   I have the sound down on the laptop as Mrs.B is watching TV in the same room.  I'm sure there's something I can learn here
2023-4-26
Blériot53
I'm wide awake this morning for a read-through of your tutorial.
I do have AutoPanoGiga already to work with, so that's a good start.
I notice that the three  composited images that you use to assemble the AEB final image, each show the digger at a different angle.
I intuit that the "Remove Ghosts"  command discards two and just leaves the central one.
Now i must have a go !
Thanks Peter.
2023-4-26
Montfrooij
Blériot53 Posted at 4-26 13:13
Yeah, I get it.
2023-4-27
Montfrooij
Blériot53 Posted at 4-26 22:45
Nice!
Yeah, remove ghost will try and take care of exactly that.
If you don't check that, it will end up making a blurry mess.
Somehow it got quite good at knowing this yellow thing moved around and should be taken from one exposure (the one that matches the desired output the best)
2023-4-27
Blériot53
Montfrooij Posted at 4-27 22:58
Nice!
Well it did a great job for you.
Now I need some footage to try out the editing technique.
No chance today it's raining steadily
2023-4-27
Montfrooij
Blériot53 Posted at 4-27 23:00
I also use it on 'normal' (non panoramic) shots a lot.
It is some more work, but very much worth the effort (for me).
You can go crazy with this HDR merge tool, but also be quite realistic.
There are a quite a few options on the right side of the menu in Affinity Photo, but if you want, I think I can share some of my presets so you can import them.
2023-4-27
Blériot53
Montfrooij Posted at 4-27 23:02
I've only used it for 360 Panos so far. But now the Mini3Pro AND the M2Z do that in-camera I've used it less. This will be a new learning curve for me, so I'll take any help I can get
Thanks!
2023-4-27
Montfrooij
Blériot53 Posted at 4-27 23:07
Thanks!
Sorry, I mean Affinity Photo
2023-4-27
Blériot53
Montfrooij Posted at 4-27 23:08
AH, we're talking at cross purposes then. I was thinking AutoPanoGiga
2023-4-27
Montfrooij
Blériot53 Posted at 4-27 23:14
Yeah, that is 'just' for panos.
2023-4-27
Blériot53
Montfrooij Posted at 4-27 23:19
Darn
2023-4-27
Montfrooij
I think it can do AEB merges, but not as well as Affinity.
2023-4-27
Blériot53
Montfrooij Posted at 4-27 23:29
Too bad for me
2023-4-27
Montfrooij
You can get it
No problem.
2023-4-27
Blériot53
Montfrooij Posted at 4-27 23:36
You can get it
No problem.
Do you have a weblink for it?
2023-4-27
Montfrooij
Blériot53 Posted at 4-27 23:43
They did increase the price a bit, but still very cheap compared to Photoshop.
https://affinity.serif.com/en-gb/photo/
2023-4-27
DAFlys
When I have some time I will try your technique.
2023-4-27
Montfrooij
DAFlys Posted at 4-27 23:48
After a lot of tweaking, this seems to be the fastest way to get good results out of a manually created AEB-3 panoramic image.
2023-4-27
Blériot53
Montfrooij Posted at 4-27 23:46
Thanks for the link
2023-4-28
Montfrooij
You're welcome.
It's quite a deep program, but I mainly use it for this HDR merge too, which is quite good (and better than the one Photoshop has)
2023-4-28
DAFlys
Montfrooij Posted at 4-27 23:50
I usually just let Lightroom do its thing,  now that I know about the catch with the 3x3 pano on the mini 3 with its raws.
2023-4-28
Montfrooij
DAFlys Posted at 4-28 04:15
even the 3AEB gives you more headroom and color information to work with than the DNG.
At least, I got much better results out of the 3AEB shots than 1 DNG.
2023-4-28
DowntownRDB
Flight distance : 1722 ft
Very nice tutorial Peter.  I really like the work flow.
2023-4-28
