DJI Air 2s
818 4 2023-4-28
skawzy
Flight distance : 343766 ft
Serbia
Hi there, I bought Air 2s. I also have DJI MINI 2 and there are some flight records on my profile and on the application. Is it possible to use separate flight info such as flight distance etc...? Actually, is it possible to record this info separately?
2023-4-28
DJI Gamora
Hi, skawzy. Thank you for reaching out. If you are using one account only, you may filter the aircraft model in the DJI Fly app so that you can see the flight records of each model. However, total distance, total flight time, and total flights cannot be displayed separately.  If you wish to have these things separately, you will need to use different accounts on each drone.
2023-4-29
skawzy
Serbia
Hi DJI Gamora, thanks for your reply.
Since I'm not using DJI Mini 2 anymore, I can remove the flight data from the DJI MINI 2 and that's it.
2023-4-30
DJI Paladin
Flight distance : 318 ft
skawzy Posted at 4-30 21:19
You're welcome, skawzy. Please don't hesitate to reach us if you have other inquiries. Thank you for your valued support and happy flying!
2023-5-20
DJI Gamora
You're most welcome, skawzy. Should you need further technical questions or concerns, don't hesitate to reach us here again at DJI Forum. Have a good one.
2023-6-20
