Ali engineer
Flight distance : 827621 ft
Iraq
DJI Gamora Posted at 5-3 22:48
Hi, Ali engineer. Thank you for reaching out and we're sorry to read about what happened to your RC. Please try the following steps below:
1. Please confirm if you can turn it on by doing a short press and then a long press of the power button to power it on.
2. Please confirm whether the DJI RC has sufficient power. It is recommended to try again after charging it fully. If it cannot be charged normally, it is recommended to replace the charger and charging cable and try again. If the problem persists, please send it back for testing. (Note: If short press the power button and the indicator light does not light up, and even connected with charger still does not light up and cannot be charged normally, please send it back for testing).
I am tried every steps such us connect with cable and press power , dissconnect cable and press power for 15 seconds and changing cable source every thing i tried its useless nothing and dont showing anything even not work no sound nothing, dead dead ...
i dont know whats the reason and whats the solution ? |
