Tom_dido
Hello there.
I am posting this problem, that seems unrelated to the one already discussed here.
I am experiencing a terrible bitrate drop, on the file recorded on drone SD cards (yes, I am not speaking about the bitrate of goggles trasmission!! but the file recorded on the drone)
I did some tests after resetting camera settings (as suggested by the support, that I contacted few weeks ago), and I found out that movies recorded in normal color have nearly the double bitrate of the identical ones, recorded in d-cinelike.
This happens both in 4K and in 2.7K. I tested at 50 and 60 FPS, and the restults are nearly the same.
For example, recording in 4k:
in normal 146 Mbps - in d-cinelike 80 Mpbs
In 2.7k:
In normal: 120 Mbps - in d-cinelike 50 mpbs
50 Mpbs are unusable, at least for me. Is anybody else experiencing such problem?
BTW, this is with the second-last firmware, not the last one (so d-cinelike should be in 8bit).
