Mini 2 says 4563 feet away
797 24 2023-5-5
xboxmoddr
Flight distance : 660039 ft
Hi everyone I have a mini 2 and was out flying the other day after the app update and in my flight log I noticed it says 4563 feet away but in my screen record the app showed 315 feet away any idea why such a big difference the only thing I did not do was a compass calibration on my last flight could this cause this issue thanks in advance
2023-5-5
Sean-bumble-bee
Flight distance : 15997 ft
Are you sure you are not mixing up height and distance entries shown in the app?
Can you up load the flight log tohttps://www.phantomhelp.com/logviewer/upload/
and post the URL here?
2023-5-5
Labroides
Flight distance : 9991457 ft
No .. the compass has nothing to do with height readings.
If the drone flew normally, there was nothing wrong with the compass.
It very rarely (almost never) needs to have the compass recalibrated.compass needed calibration, you'd have known it.
Your flight data might shed some light on your issue.
2023-5-5
djiuser_E61FCQDaYZBl
Flight distance : 232720 ft
could just be an error maybe see if there is an update?
2023-5-5
Labroides
djiuser_E61FCQDaYZBl Posted at 5-5 16:25
No ,,, It "couldn't just be an error"
See if there is an update isn't going to help at all.
It's most likely that every thing was completely normal and confirming whether that was true or not by examining the flight data would be the first thing to do.
2023-5-5
DJI Tony
Hi, xboxmoddr. Thanks for reaching out, and we're sorry for the inconvenience. We sent you a PM to gather more details for further checking. Kindly check at your earliest convenience. Thank you.
2023-5-6
xboxmoddr
pm replied thanks
2023-5-7
DJI Tony
Thank you for your response. We've sent you a follow-up message. Kindly check.
2023-5-8
xboxmoddr
thankyou I'm looking in to obtaining this for you thanks
2023-5-15
DJI Tony
xboxmoddr Posted at 5-15 08:08
We appreciate your cooperation. Kindly send them via PM once ready. Have a nice day!
2023-5-16
Labroides
Why bother to post here when you've completely ignored those that offered to help?
If you had posted your flight data, you'd have had a more detailed reply than DJI give and you'd have had it 10 days ago.
2023-5-16
Sean-bumble-bee
Well said but I am sure you have seen the same thing before and will again....... but not everyone wants to put flying locations out there on the www.
2023-5-16
xboxmoddr
im sorry  i was under the impression that the flight log was for dji only its not that i ignored anyone i sent dji the flight log from the website airdata i think  but they said they needed it from the drone its self then i had a bereavement in the family so obviously that has taken priority hope you can appreciate this thanks
2023-5-16
xboxmoddr
this is the flight log thanks
https://app.airdata.com/share/qwStQn
2023-5-16
Sean-bumble-bee
The instantaneous reaction to that flight path is, were you intending to trace out a cartoon like caricature? lol. It's brilliant. (Visible on Airdata, I don't see a track on Phantomhelp.)
The log on phantomhelp = https://www.phantomhelp.com/logviewer/26RG5WL64E7A4L6XPBUP
2023-5-16
Sean-bumble-bee
Not sure where you get 4563ft from but I am left wondering if you have mixed up 'mileage' i.e. the distance covered by the drone doing the flight, 4519ft, with a distance from the home point? The maximum distance from the home point appears to be 1144ft at around 3min 50sec i.e. at the tip of the nose.
Max height appears to be 324ft relative to the take off point and probably near enough AGL as well.
2023-5-16
xboxmoddr
haha yup designing a new disney character lol
2023-5-16
Sean-bumble-bee
With regards to what DJI were/are looking for it sounds like the DAT from the drone and you may need to use the appropriate assistant 2  and a computer to get that.
2023-5-16
xboxmoddr
i have dl drone assistant 2 but when i connect my mini2 nothing happens i have tried with it powered  on and off when its powered on the only thing that happens it it showes the micro sd card in the desktop on the drone assistant it just says how to connect to inspire 2?  and i am logged in but  i can not get the data required
2023-5-26
xboxmoddr
2023-5-26
xboxmoddr
god sorry for multi post im new to MacBook pro sorry
2023-5-26
xboxmoddr
so i might be getting confused as sean says as my fly app says 4519 ft i just presumed this was the distance away not total flight so if this is the case then i am a noob sorry thanks for all the help but i still can not connect via drone assistant
2023-5-26
xboxmoddr
i think i may of dl the wrong drone assistant just trying the consumer one
2023-5-26
Labroides
xboxmoddr Posted at 5-26 02:27
Forget about getting anything to DJI.
It's not needed.
You can view a good summary of your flight here:
https://www.phantomhelp.com/logviewer/7OE3NJ8IM1UMM8T97YH0/
Look at the data there and you can see that the maximum distance shown anywhere during the flight was 1144 ft.
There was never anything wrong with the drone and it was just confusion.
2023-5-26
xboxmoddr
many thanks its not hard to confuse me lol thanks again
2023-5-26
