Sean-bumble-bee
Flight distance : 15997 ft
Computerised in a csv, data taken from the csv of each log, 3800+ logs to date and I have lost a few grr mainly from the Phantoms.
Column titles :-
logname,
Drone_type_$63, drone_name_$234, drone_sn(a)_$263, drone_sn(b)_$233, drone_act_date_$235, DAT_file_nos_$210, Firmware_Ver_$240, cameraSN_a, $236, cameraSN_b, $264 (that group was/is aimed at identifying the drone since, and especially from the P3's, some data channels were/are occasionally empty),
controller_sn(a)_$237, controller_sn(b)_$265, (again the two serial numbers so that I could hopefully ID the controller used, I tend to swap controllers, more needed with the P3's )
App_Ver_$232,
battery-sn(a)_(JF)_$266, battery-sn(b)_(ID)_$238, bat_cent_cell_sn_(DP)_$120, bat_prod_dat_(DQ)_$121, charge-count_(U)_$111, (aimed at ID'ing the battery used since especially from the P3's some data channels were occasionally empty)
Flight_length_(sec)_(IS)_$253, Drone_switched_on_time_(sec)_(BH)_$60, bat_volt_start_(V)_(EJ)_$140), bat_volt_end_(V)_(EJ)_$140, bat_perc_start_$146, bat_perc_end=$146,
Latitude_(deg)_$13, Longitude_(deg)_$14, max_distance_running_(m)_$11, Distance, travelled_(m)_$10, Distance, travelled_mine_(m)_$10 (calculated from the summation instananeous speeds multiplied by last time increment) ,
max-height_(m)_$254, height_difference=landing-take_off_(m)_$15, flying_alt_(m)_$15, log_start_height_(m)_$15, ave_+ve_height_(m)_$15, ave_-ve_height_(m)_$15, lowest_point_(m)_$15,
Total_climb_flight(m)_$15, Total_climb_ALL(m)_$15 (calcultaed from summation of instantaneous climbs),
Max_pitch_forward_$20, Max_pitch_reverse_$20, Max_roll_right_$21, Max_roll_left_$21, max_speed_(m/s)_$255, max_descent_rate_(m/s)_$256, max_climb_rate_(m/s)_$19,
Gimbal_down_(BR)_$70, gimbal_down_average_$70, Gimbal_up_(BR)_$70, gimbal_up_average, ( got curious about gimbal tilts so added these )
isPhoto=YES/TRUE_$2_$63_$64_$66, DETAILS.photoNum_(IW)_$257, video_count_$165, ( aimed at belatedly possibly working out what drone took what photos etc. )
card_size_(kb)_(FU)_$177, card_space_start_(kb)_$178, card_space_end_(kb)_$178, Card_space_used_(kb)_$178, Max_GPS_sats_$50, Av_GPS_sats_$50, Nos_of_lines_$248, flightdate_from_FILENAME, Nos_RTHs_in_flight_$23, Running_total_no_of_RTHs_$23,
set_height, limit/s_(m)_PH_CSVs_ONLY, set_go_home_height/s_(m)_$205, take_off_AMSL_(m)
$xyz & (ab) are the column number/ names in the P3 csv's they differ in other models but I find them to be a useful reference.
The program requires linux and the language Gawk or perhaps Awk, so of no use to anyone without both unless they want to rework the program. I have no doubt a pro would think the program is an absolute 'horlicks' but I am not a programmer and it works ..... for me lol
