DJI ‎O3 Air Unit - Stays blurry / Out of focus
2535 3 2023-5-16
Corebee
Hello together,
I recently ran in to an Issue with my DJI ‎O3 Air Unit. It's bound to a DJI FPV Goggles V2.
Since yesterday the camera doesn't focus anymore and stays only focused/clear on very close objects.
Several cleanings of the lense (it's 100% clean now) didn't change it. I also tried to figure out different options and settings for the camera which could probably fix it (AutoFocus, Manual Focus, FOV, etc...) but nothing changed.
I also did a Firmware-Refresh with latest version without any success.
To have a feeling what it acutally looks like, please see these pictures.
Picture 1: It should be clearly visible, that the trees and buildings in the distance stays blurry, no adjustments by the Air Unit.
no focus
no focus
Picture 2: On the bottom it should be visible how the close ground-tiles are clearly focused.
close focus
close focus
If there is any further Information needed to fix this issues, please let me know. Any ideas and suggestions are appreciated.
The Air Unit is about 6 months old, and had no issues so far.
Regards
2023-5-16
Corebee
I sent it in as a repair-request to DJI and it will get replaced.
2023-5-24
djiuser_1vU2LUzNpolv
Flight distance : 3172920 ft
Did you contact support first and they told you to send it in for repair? Just wondering, because this same issue just happened to me. I'm trying to figure out what to do about it.
2023-5-25
Corebee
djiuser_1vU2LUzNpolv Posted at 5-25 07:33
Yes. That's the way. With the chat-support i did the recommended steps like, firmware reset and so on. After all this, it didn't fix the problem, so the support asked me to open a new repair request and send it in for further investigation.
You can open a repair request here: https://repair.dji.com/
In the end DJI will check the product. If it's a warranty issue, the replacement can be free of charge. Which it was in my case.
Very convincing and nice job by DJI.
2023-5-25
