Labroides
Flight distance : 9991457 ft
digibud Posted at 5-18 11:14
I assume I need to pay for airdata to see that information, eh? Could you expand upon what you are learning. Is the notice on the screen that I got about No GPS not valid? I am seeing others on the mavicpilots.com web site mentioning similar issues since the last firmware update. Any further thoughts? As I mentioned, a recent short test showed no problems and flights subsequent to that problematic flight on that day didn't show further issues. It may just be a singular oddity although with others chiming in with similar observations I am led to believe it may be an issue that is now being seen and since I have LatLong showing all the time it may be just a false reporting. Why my
It's not entirely valid.
You never lost GPS reception.
There were 16 times during the flight between 6:51 and 10:34, when the flight controller registered no confidence in the GPS location data.
These ranged from 1-15 seconds.
But each time, the data still shows that the flight controller was calculating speed and position data for every 1/10th of a second based on the GPS data, and the column labelled Is GPS used, shows True for all of these periods, just as it does for the rest of the flight.
Whatever caused the flight controller to register zero for GPS reliability in those periods is a mystery, but it looks like your drone had full normal GPS the whole time.
If you don't see this again, just write it off to a one-off glitch.
If it shows up in the future, ask DJI for an explanation.
