Solved-Screen recording wont show up on RC album
1544 17 2023-5-31
Ranjan
India
SOLVED - A possible bug is found which is why it wasnt showing.
refer my below post number #9
Since yesterday afternoon flight all was good & evening flights I noticed 2 things gone wrong.
1. Screen recordings are happening & I could access it by connecting RC to Mac but they are not showing up at all in the RC album.
2. Somehow without me even opening the dialog box the settings were changed to Default auto WB, Jpg Only (instead of J+R)
What could be the problem?
My last option would be to factory reset the RC but if the problem can be sorted I would first like to do that.
2023-5-31
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
1) To view, you just need to select the appropriate Album.
2) There is such a thing on the latest firmware.
2023-6-1
Mobilehomer
Flight distance : 18135846 ft
Screen recording is on the device, not the craft. This is why it doesn't show in the fly app.
2023-6-1
Ranjan
India
Mobilehomer Posted at 6-1 06:31
I am aware of that RC holds the screen recording & that's what I am try to play on in the RC album but its not showing me any data, where as when I connect the RC to my desktop & navigate to the folder the recorded files are indeed there.
2023-6-1
Ranjan
India
Drone.Hunter Posted at 6-1 05:30
Those albums are not showing me the thumbnails of recorded videos that's the problem.
2023-6-1
Drone.Hunter
Kazakhstan
Albom name: "Movies"
2023-6-1
Ranjan
India
thsi is what its showing me all blank
This is showing up no data
2023-6-1
Mobilehomer
You cannot access them through the Fly App. Look in Gallery on the RC.
2023-6-1
Ranjan
India
Mobilehomer Posted at 6-1 07:54
I don't see any other option for gallery on Rc, could you please share any online video or screenshots .
Seems my brain is getting older as I remember that I was able to see screen recordings under saved videos & saved screenshot under Photos as seen in the screenshot I shared.
2023-6-1
Ranjan
India
My notifications were not showing me SD card mounted so I decided to format the Sd card & it started showing me notification & SD card mounted & screen recording working fine & showing me in the gallery.
I then tested what caused the problem & here is a bug I found, other users might confirm this & report here so Dji can solve this bug.
If you cancel silent notification by clicking on X mark then the notification wont show & you cant access the gallery on SD card.
Only Solution is to again format the SD card in the RC controller & then it will start showing Sd card mounted notification.
DO NOT CLICK THE X MARK TO SWITCH OFF NOTIFICATION  else the card will not show its data.
2023-6-1
Drone.Hunter
Kazakhstan
Ranjan Posted at 6-1 07:31
Click on "Saved" at the very top and you will have a selection of folders in the Gallery.
2023-6-1
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We're glad that you already managed to isolate the issue that you experience. Please note that we can only perform screen recording on the DJI RC if you have an SD card inserted into the unit. If you experience this kind of issue, you may back up the files and reformat the card or use a different SD card to isolate the issue. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
2023-6-1
Ranjan
India
DJI Paladin Posted at 6-1 19:24
Thanks Dji Paladin,
can you please report this bug as mentioned so the software team can solve the notification problem in next update.
The Bug is If you cancel silent notification by clicking on X mark then the notification wont show at all & you cant access the gallery on SD card but the recordings are still getting saved on the card.
Only Solution is to again format the SD card in the RC controller & then it will start showing sd card mounted notification.
2023-6-1
djiuser_x4UoKI0LRn10
Flight distance : 31161 ft
If you click on the settings button, far upper right corner, you can go to storage. Internal and sd card will show up. I can't view anything on the sd card, but when I click on the internal storage and then photos my screen recordings show up there. However they are being saved on the sd card, no idea why you can see them on internal storage.
2023-6-2
Drone.Hunter
Kazakhstan
Ranjan Posted at 6-1 19:33
Thanks Dji Paladin,
I ask again, have you tried switching Albums in the Gallery?
2023-6-2
Ranjan
India
Drone.Hunter Posted at 6-2 07:36
In my case those album was not showing up at all, after formatting the sd card it works fine now.
2023-6-2
DJI Paladin
Thanks Dji Paladin,
Hi, Ranjan. Yes, we will coordinate this request of yours to our designated team for attention. Thank you for your valued support.
2023-6-3
Zappa88
Thanks so much for the solution. Today was my first flight and wanted the screen recording off it. Had to remove the SD card (with difficulty) to get to the file.
2023-7-9
