SkyCryer
Flight distance : 1584596 ft
I was creating some waypoints for video and hyperlapse to protocol my house building. The video waypoints are working fine, as long as i use the same startpoint, i know.
But the hyperlapse waypoints are not working anymore after some days. So i create the hyperlapse waypoints, save them. Then next time i use the same starting point but only sometimes they still work. Today i wanted to use a saved waypoint, it works some days back after oading correct. But today the drone wanted to go extrem low, the waypoint is at 41 Meters. But this time i had to stop it going below 21 meters, that is way of.
So i just wondering if i do something wrong or if there is a known bug. Did others had the same problem and could solve it?
As said my starting point/height is the same everytime so that is not a problem. And as far as i know DJI is using barometric perssure to calculate the high. But my starting point is used, right? So as long as i use the same starting height, even if pressure did change in the last days after i created the mission, it should be correct because of the starting high, or not?
