Is it possible to charge the Integra with a 65W adapter?
3670 14 2023-6-14
Jukeboxandi
Flight distance : 117979 ft
Hey everyone. I'm wondering if it's ok to charge the Integra goggles with a (third party) 65W adapter or if that can cause damage to the battery. Thank you for your time and consideration.
2023-6-14
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We highly recommend using an 18W PD charger when charging your DJI Goggles Integra to avoid issues. We will clarify this with our relevant team if the unit will support a 65W charger. We will keep you posted. Thank you for your patience and understanding.
2023-6-14
djiuser_SGLQDd0TNdCA
What is the best charger? And about motion controller 2? Tk you
2023-6-15
Jukeboxandi
djiuser_SGLQDd0TNdCA Posted at 6-15 11:33
Hi, I found out using a standard power adapter for your phone is enough to load the motion controller and the goggles. For the batteries it‘s necessary to use a 65W adapter.
But still … I‘m wondering if it‘s ok to use a 65W for the goggles and controller is ok anyway or if it would cause damage to the batteries inside the devices.
2023-6-20
Jukeboxandi
DJI Paladin Posted at 6-14 18:23
Hey, thank you so much. Did you find out an answer yet?
2023-6-20
Geo_Drone
Flight distance : 2676129 ft
Romania
You can charge Integra with 100W power adapter without any issues.
Any electrician will tell you that is not about the power you give, but about voltage stability.
So if you put 100W charger to Integra, the battery will charge using the max power charging regulated by the battery circuits, not by power adapter...
A battery that charges at 18W for example, even if you put it at 1000 W power adapter, will take only 18 W from that adapter.
This is how electronics works...
PS. I use a 65Watt PC adapter with USBC. Is very stable, does not induce noise and oscillations in supplied power...is better than any DJI charger you can get.
2023-6-20
DJI Paladin
Jukeboxandi Posted at 6-20 03:09
Sorry for the late response. If the charger supports the PD charger protocol, it is compatible. However, it will decrease to Goggles max charging power which is 15 W (charging when powered off). We highly recommend using a DJI charger. Thank you for your valued support.
2023-6-22
dnddad324
Flight distance : 12536706 ft
DJI Paladin Posted at 6-22 02:27
I would've gladly bought the DJI branded PD 65W charger if the price wasn't double than any other. I spent 30% of DJI's price for a Best Buy brand PD 65W charger and it works perfectly.
2023-6-22
DJI Paladin
dnddad324 Posted at 6-22 05:44
We appreciate you for sharing your experience about this concern, dnddad324. Please don't hesitate to reach us if you have other inquiries. Have a wonderful day ahead!
2023-6-24
R3Ramzova
Czechia
Hello, I was wondering if this charger will work properly https://www.baseus.com/products/powermega-3-ports-fast-charger-140w with Dji Mini 4 pro ?
Thanks
2-1 07:10
Manitobahunter
I have several different Anker wall charge blocks and a couple power banks, and have used them for years with the DJI drones, controllers and goggles. As long as a charger is from a reputable company, ( I also have a couple Samsung charge blocs ), support the PD protocol, and you are using a PD power cable, it's not nessesary to use a DJI charger, which will be manufactured by another company anyway...
The more watts the charger is rated for the better, as it will communicate with your device and provide the correct wattage for your devices charging requirements. So a charge block rated for 30 watts max, thats putting out 30 watts for a couple hours charging up a hub full of Mini 4 Pro batteries is working hard at its max capacity,  where as a 100 watt max charge block is just idling away charging at 30 watts and likely making things easier for all items concerned.
2-4 12:35
DJI Tony
R3Ramzova Posted at 2-1 07:10
Thanks
Hi there. DJI Mini 4 Pro uses the commonly available USB-C port for charging. You can directly use chargers with this type of port, such as those used for Android devices or Mac. Please rest assured that it will not damage your battery. Have a nice day.
2-5 02:28
phantomNOGO
Why does DJI need to make it so difficult to charge a $500 device safely? Are they making $ of the kids who cant wait for the charger and fry them?
3-17 10:07
phantomNOGO
DJI Paladin Posted at 2023-6-14 18:23
Why is this so confusing for your customers? Why isnt there clear directions in the device I bought for safe charging, and no reference to the fact no charger is included
3-17 10:09
DJI Paladin
phantomNOGO Posted at 3-17 10:09
Hi there. Thank you for reaching out and we do apologize for the trouble. Can you please confirm what specific DJI product are you referring to? Kindly tell us if you have purchased a combo or a single product and if you purchase it on our store website directly. Please keep us posted.
3-18 00:39
