Altitude Limit problem
701 5 2023-7-27
SOP77
Flight distance : 672582 ft
Hello to the community,
I have a problem with a Mavic 3 Ciné Prem, i can't have a altitude limitation, i set 30 meters (or whatever) but it continues to climb and climb without stopping. Do you know this problem ?
Many thanks !!
regards
Duch
2023-7-27
Sean-bumble-bee
Flight distance : 15997 ft
Can you post the .txt flight log of a flight where this occurs? For instruction on how to retrieve the flight log see lower down
https://www.phantomhelp.com/logviewer/upload/
2023-7-27
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please try to have a test flight in an open location with a strong signal and please provide us a screen recording showing the live feed during the issue so we can check it further. Please keep us posted. Thank you.
2023-7-27
Sean-bumble-bee
DO NOT try a test flight to those heights unless you are sending the drone up a hill that climbs to at least 380m above the take off point.
2023-7-28
SOP77
After some tests, this happens after unlocking NFZ certificates, imported into RCpro...
The altitud limit is functional when the certificates are deleted.
2023-8-7
SOP77
Sean-bumble-bee Posted at 7-28 00:48
Thanks to remind me, i perfectly know what to do.
regards
2023-8-7
