rc will not connect to drone
676 6 2023-8-17
djiuser_zUB1nkuh149w
Weirdness started yesterday. the remote is sitting beside the drone.  I get the image transfer signal warning right away.  If I go into transmission options it's set to dual band auto channel mode.
if I manually change it to 2.4ghz,  it works fine.  if I change it to use  5.8ghz it will not connect at all. so every time I start the rc I need to manually change it to 2.4ghz. then all is well in my world.   its never done this until yesterday.
I refreshed both drone and rc using dji assistant with no change in behavior.
Just tried again and the 'Tranmission' windows shows nothing
Thanks for listening
Fred
2023-8-17
fansebae
Flight distance : 7672598 ft
remove the microsd from the drone and see if that helps. I've had similar trouble with some crap cards.
2023-8-17
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please send us a screenshot showing the error message you received on the app? If you could provide us a short screen recording showing the issue that would be very helpful so we can check. You may upload the files via Google Drive. Please keep us posted. Thank you.
2023-8-17
DJI Paladin Posted at 8-17 18:39
Hope this helps, it won't let me change the frequency at all this morning
https://share.icloud.com/photos/034K2brZ4fiEzIebBL6FVxyUw
2023-8-18
DJI Paladin
djiuser_zUB1nkuh149w Posted at 8-18 03:33
Thank you for your response. Kindly please test the unit outside with a strong GPS signal to see if the issue persists. Please record the screen if you still experience any errors outdoors so we can check. Thank you for your cooperation.
2023-8-19
Same behavior. I only Brought it in to video it with better light. I have another rc. I’ll unbind both and bind the workable one and see.
2023-8-19
I have two mini 3 pro's
drone (A)
drone (B)
RC (A)
RC(B)
drone A I sent to dji for care refresh
now I have
drone (B)
RC (B)
RC (A)
Drone (B) and RC (B) is having the transmission problem
Can I unbind both RC's
bind  RC(A) to Drone (B)
to test if this works.
2023-8-19
