Andreja
Flight distance : 1085302 ft
Well, I just received mine, will try to test it when I get a chance...
One thing which I found a bit strange (compared to Mini 3 Pro, which is my other drone), is that the Air 3 doesn't report that it has detected the wide angle lens, so it's not really possible to see that it has been attached in the UI.
Anyway, here are the details from the manual:
Pano and Asteroid don't work with wide-angle lens.
Mass of the lens: 9.2 g
Field of view: 114°
Equivalent focal length: 14 mm
The lens itself goes on top of the 1X camera, so the 3X camera is not affected by it.
The manual for the lens states that the gimbal should be rotated to be level and pointing forward, but, as franceslup mentioned, the lens is so heavy that the gimbal can't hold its position with the motors off, so that's a bit strange. |
