Integra goggles fail to connect to O3 air unit
637 10 2023-9-28
djiuser_buvmLC8W1X6h
Flight distance : 47500 ft
Both goggles and O3 are updated to latest firmware. Binding was successful and O3 mode is selected. Goggles attempting to connect to O3 but after few seconds they return a fail message saying to select the O3 mode or connect the goggles to O3. I also noticed that all options under the menu Transmission >Pilot are greyed out and cannot be amended. Not sure if this is related but i would expect that these options were active. Please help
2023-9-28
DJI Thor
Flight distance : 13602 ft
Hi there, thank you for reaching out. In order to better to assist, would you please provide us a video recording? We will forward to our engnineer team to further check, thanks.
2023-9-29
Thank you for the quick response. I ordered a new FC/ESC to connect the O3 so i can eliminate any possibility that the issue is not between the Integra and the O3. I will then revert with a video. Probably end of the coming week.
Many thanks,
Petros
2023-9-30
DJI Susan
djiuser_buvmLC8W1X6h Posted at 9-30 13:00
Many thanks,
Petros
Thank you, Petros, we look forward to your reply.
2023-9-30
Hi, i received the new FC but nothing changed. I recorded 3 short clips that show the problem. How can I send you the videos?
2023-10-6
DJI Wanda
djiuser_buvmLC8W1X6h Posted at 10-6 10:38
Hi, would you please upload it to a cloud drive and share it with us?
Please remember to open to all.
2023-10-6
https://www.dropbox.com/scl/fi/nf0u1d3x25pli19joolbw/20231006_191027.mp4?rlkey=c403kxu5bul0gkk03bde9obdg&dl=0
2023-10-7
I am just sending you for your record...in case other users face the same issue. Because i have managed to solve the problem. What i did is just binding again the goggles with the O3. Still not sure why i was facing the problem since the initial binding process completed successfully and resulted in O3 added to my modes options. The transmission/ pilot menu also works after the second binding. Thank you for your support
2023-10-7
DJI Wanda
djiuser_buvmLC8W1X6h Posted at 10-7 12:55
Thank you for the updates. Just to double confirm the issue has been resolved, right?
Please let us know if you have any issues.
2023-10-7
The issue has bee resolved.
2023-10-7
DJI Wanda
djiuser_buvmLC8W1X6h Posted at 10-7 22:59
Noted. Please feel free to talk if you have any questions.
2023-10-8
