Disable VPS when flying outdoors?
2634 16 2015-9-3
Bunkx9
Flight distance : 136946 ft
Anyone else keep the VPS off on routine outdoor flights? I feel it's more of a detriment to the P3 when you have strong GPS lock.
2015-9-3
Flight Raptor
Flight distance : 3014675 ft
Keep mine one...never had an issue.  What detriment do you think it might have?
2015-9-3
jimcloud74
Flight distance : 1298317 ft
Auto landing will not work properly along with auto takeoff if you disable. (if you care) ;)
2015-9-3
rayrokni
Flight distance : 8139875 ft
i have mine always  turned off when over water!  i used to have it enabled at other times until one day i was up 300'+ and i noticed the VPS was saying i was up 12'. from that day on i have had it switched off. i dont fly indoors, i dont use auto take off, i dont use auto land, and i dont fly 9'(the max range of vps) off the ground. so i cant see the benefits for me.
2015-9-3
Rigworker
Flight distance : 52303 ft
I have only turned it off a couple times to test it. Now it is always on.
2015-9-3
boxerman
Flight distance : 39695 ft
Never turn them off - fly mostly over water.
2015-9-3
buzzcbr
Flight distance : 316545 ft
Mines never turned on, dont need it, never use it.
Also 99% of my flights are over water (live on the coast) so not gonna risk it.
Buzz
2015-9-4
Bunkx9
Flight Raptor Posted at 2015-9-3 23:33
If I'm understanding what the instructions are telling me, the P3 uses VPS from 0-10ft. Above 10ft, it switches to GPS only to orient/stabilize.
The detriment would be that GPS lock is more reliable/accurate in keeping the P3 stable, isn't effected my light conditions/water/certain patterns that are said to throw off the VPS system.
My "trainer quad" was the Parrot AR 2.0. It uses the same VPS/sonar sensors for flight and altitude control. It wasn't accurate at all, but I'm really glad I learned to fly a quad with it. It's makes flying the P3 a breeze.
Side note: First flight with carbon fiber props last night. WOW. Love those things. It's A LOT more quiet and responsive.
2015-9-4
Flight Raptor
rayrokni Posted at 2015-9-4 12:04
i have mine always  turned off when over water!  i used to have it enabled at other times until one  ...
Very interesting observation.....hmmm...making me rethink my habits here....
2015-9-4
rayrokni
Flight Raptor Posted at 2015-9-4 22:18
let me be a bit more clear,  i turn it off not because they malfunction, i turn it off because i dont  use it and since there are debates about it  i dont need to risk using  something that is not useful to me. if i flew indoors or auto take off and land, i could see the reason to enable vps.
2015-9-4
QuikSilver15
Bunkx9@yahoo.co Posted at 2015-9-4 09:47
If I'm understanding what the instructions are telling me, the P3 uses VPS from 0-10ft. Above 10ft ...
Can you link the props you used for your phantom 3? Thanks!
2015-9-4
rayrokni
QuikSilver15 Posted at 2015-9-4 23:54
go to dji store and there u will see the carbon fiber reinforced props, $15 for 2 so $30 for a set and in my opinion well worth it. careful there are some fake ones out there. that is why i buy direct from dji, specially things that keep it in the air!!
2015-9-4
Flight Raptor
In addition to Ray's post, here's where I got mine and I LOVE em...
http://www.amazon.com/DJI-Reinfo ... SVBREYXMS5A1A8QTV9S
2015-9-4
rayrokni
Flight Raptor Posted at 2015-9-5 00:24
http://www.amazon.com/DJI-Rein ...
amazon would be cheaper as there is a $20 shipping fee from DJI, but be careful of knock-offs.
2015-9-4
Flight Raptor
rayrokni Posted at 2015-9-5 00:30
Couldn't agree more.  For the record, these were the genuine DJI parts that came in the Genuine DJI packaging of 2pcs per pkg.
2015-9-4
tcmitch1
Ok now to add to this thread....
I recently returned my P3 Standard and bought the Pro.
I do plan on turning off the VPS feature as I fly mostly outdoors too.
My question.... would turning off this feature make the battery run longer on a full charge?  Does the VPS use more battery power vs not using it?
Thanks
Todd
2016-1-5
DJI-Patrick
tcmitch1 Posted at 2016-1-6 00:55
I do plan  ...
The VPS doesn't  run much power . I doubt it would make a big difference on flight time .
2016-1-5
