In flight problems after 1.3.0 FW update
1697 12 2015-9-5
chris
Flight distance : 242247 ft
First time able to fly here in the Arizona desert because oftemps well above 100f.  Most of theproblems are navigational. All preflight check’s done, including IMU andCompass calibration done. Everything looks good to GO.
1. Right away once at about 6 feet in the air and pushing theleft stick forward the bird goes sideways to the right. After stopping, thengoing forward again the bird stays on track in a straight line. While going straightahead as I bank left slowly then stick straight forward the bird goes on aright side move, not straight.
2. When raising landing gear while hovering about 5 feet thebird climbs another 4 feet. When lowering gear while at a 6 to 15 foot hoverthe bird loses about 5 foot in altitude.
3. Whenever I’m flying forward and about 20+ knots then slowdownto a complete stop, the bird loses about 5+ feet in altitude.
4. Several time’s during today’s flights I’m losing connectionto the bird, flight controls still active. I’m guessing this is the DJI GO appproblem.
5. Did the FW update about 3 weeks ago and selected thedischarge to start at 1 day for storage. Today all the Batts were at about 87%.
I’ve been flying the I1 over the past 6 months with noproblems at all; it’s been rock solid until the 1.3 update.
Grounding the bird until DJI gets the FW fixed.
2015-9-5
bharkup
Flight distance : 10425610 ft
I have the same problems. Even in fast foward flight you can hear the motors fight them selves. I then put previous fw back in, the inspire is rock solid again but now I lose video feed after about 150m. The motors still fight each other in fast flight. So I've gone back to current fw so I can still get video feed.
2015-9-5
Linolens
Flight distance : 501250 ft
Macao
it's not a FW issue.
My I1 it's performing flawlessly.
Yes I see that braking is less aggressive, more Phantom like but besides that...no issues.
Video feed has also been spot on. A little lag but I'm guessing that's interference from where I live at.
2015-9-5
bharkup
Well these symptoms only happen since firmware update. Plenty of others have the same problems.
2015-9-5
Farnk666
Flight distance : 1711394 ft
I'd agree that flight behavior has changed with this fw.
Have seen some vertical drift down, esp during turns or sweeping arcs.
I haven't seen signal loss issues on the primary controller (slave controller is a separate issue) but I don't let the inspire get very far from me while airborne.
2015-9-5
tim foster
Flight distance : 1762359 ft
best to stay on .06 that seems to be the best firmware to date!! im on pilot app 1.1.2 and having no flight issues i am however having gimbal horizon problems very frustrating!!! for a 3000 doller bird......
2015-9-6
kasper.levison
Sweden
The same here ! Signal lost, all the time. This never happened before the upgrade.
2015-9-7
hcpilot
Flight distance : 33763 ft
I live in Anthem and i have been flying all summer!!! Heat hasnt affected my Inspire 1 at all!!!!
2015-9-7
chris
hcpilot@cox.net Posted at 2015-9-7 13:12
I'm in Anthem as well, glad to hear another I1 is in the area. I'm just not taking the chance during the heat as I don't need to have the bird in the air until next month.
2015-9-7
hcpilot
Did they kick you out of the park too?? :@
2015-9-7
chris
hcpilot@cox.net Posted at 2015-9-7 14:56
I got the info before I flew there. I did however get permission from the CC to do an aerial video of the park and memorial last year.
2015-9-7
blackcruiser
Flight distance : 684055 ft
Singapore
Do you guys feel the inspire is flying slower now with firmware 1.3?
I also realize that the bird will start hoovering away from the take off points once in a while.
2015-9-7
chris
Slower and very unstable. Looking at loading the previous FW.
2015-9-8
