DJI Rc Plus - where to find Expo curves?
1122 18 2023-11-7
Panph
Flight distance : 5322589 ft
Hi everyone, i recently bought the DJI Rc Plus for my M300.
I cannot find where to set the Expo curves for the joysticks. Nothing in the aircraft tab, neither on the controller tab. In the other drones is easy to find under the aircraft settings.
Anyone knows where to find this settings? the default is too much sensitive for me.
2023-11-7
Craig_Tas
Flight distance : 2998255 ft
I have also looked and can't find the option. It is way more twitchy on this controller than the factory one that's for sure.
The rubber boots don't restrict the movement as much on this controller which I think is part of the issue.
2023-11-7
DJI Wanda
Hello, there. DJI Matrice 300 does not support adjust EXPO settings on DJI RC Plus.
2023-11-16
Shin_T_PILOT
Flight distance : 337411 ft
Japan
I feel the same way. RC Plus's response is quick. I want to adjust it a little more slowly.
2023-11-17
Hoarfrost
Flight distance : 705974 ft
DJI Wanda Posted at 11-16 05:45
I notice this is an issue while flying my M30. When flying such a large drone, the inertia from its weight means there is more overshoot made worse by fast responses to even small stick movements.
Why can't this be adjusted? I would feel that, especially when doing inspections in sensitive areas, that precision flying would be more important than flying my Mavic 3 or Mini 3 Pro for example.
Can DJI please consider a firmware update that allows adjusting the sensitivity of control inputs? Anything that can help improve the safety, resolution and repeatability of flying these large drones would be greatly appreciated.
2023-11-19
Panph
Hoarfrost Posted at 11-19 15:19
I completely agree.
I use to switch to tripod while inspections or to make small adjust movements in complex environment, but for sure, expo could come in handy....
I don't think it's a difficult thing to add....
2023-11-20
DJI Wanda
Hello, there. Starting from firmware version v7.1 (drone: v07.01.00.26, remote controller: v02.02.04.05), Matrice 30 Series supports Gain & Expo Tuning. May we know if your M30 does not support it?
2023-11-21
Hoarfrost
DJI Wanda Posted at 11-21 00:43
Thank you for pointing that out. I had adjusted the roll as low as possible and it's still too fast. I'll adjust the Expo to a lower setting and see if that gives me the control I'm looking for.
2023-11-21
DJI Wanda
Hoarfrost Posted at 11-21 07:05
Got it. Please tell us your feedback.
2023-11-22
Panph
Hi DJI, i'd like to invite your tecnicians to implement this function asap.
Yesterday i've done a mission with very low temperatures, -2°C for 3 hours, even with gloves (without fingers) my hands were freezing, this causes a very low sensitivity of what my fingers was doing. With this set up, with the stick so sensitive was almost impossible to fly safely while approaching for landing. Millimetrical move of the stick is a big (and fast) movement of the M300.
Thank you.
2023-11-24
cessna1525
facing the same issue, movements are too abrupt in new DJI M350, not ideal when carrying a sensitive payload, also I don't why it cant do adaptive bank turns in auto mode, without stopping at every waypoint.
2023-11-30
Hoarfrost
DJI Wanda Posted at 11-22 03:51
I lowered the expo sensitivity and was able to better control the drone, especially when landing in windy conditions.
It would be great if there were separate settings for each mode or a way to map a preset expo setting to a button for turning on/off more precise control at will when doing inspections in close quarters or dangerous/windy locations.
2023-12-19
AmazingUser22
Flight distance : 2627959 ft
You can adjust the speed the gimbal pans in settings btw
2023-12-19
Hoarfrost
AmazingUser22 Posted at 12-19 11:11
That wasn't my issue. My issue was controlling the speed of the drone rolling right and left. The OOTB settings are way too fast for precise control in wind or close quarters.
The addition of the Expo settings for the Matrice 30 drones was a welcome firmware update.
2023-12-19
DJI Wanda
Hoarfrost Posted at 12-19 10:56
Thank you for your reply. Currently, there are no separate settings for EXPO. We will forward your request to our engineers teams.
2023-12-20
Hoarfrost
DJI Wanda Posted at 2023-12-20 03:38
I don't know when things changed, but I just checked again and now I see that I can make separate gain and expo adjustments for each flight mode - Normal, Sport and Tripod in the Gain and Expo Tuning section.
These options only show up when the drone is connected.
1-30 20:45
TimmyBaker
Flight distance : 4762051 ft
South Africa
Any word on these EXPO and GAIN adjustments coming to the M300?
Have broken a few gimbal dampers because they tear due to the impossible nature of coming to a smooth stop...  Even when flying slow and you back off the pressure the drone does an abrupt hard stop, no only bad for the payload and gimbal dampers but also makes the operator look like they dont know how to fly a drone and just a stick banger....
2-8 04:35
LV_Forestry
Flight distance : 4726654 ft
Latvia
TimmyBaker Posted at 2-8 04:35
I have this hard brake issue when I release the stick suddenly. Otherwise manual flight is very smooth.
Putting EXPO will not change the problem. It is this fast auto break feature which is annoying.
2-8 04:44
TimmyBaker
South Africa
LV_Forestry Posted at 2-8 04:44
No doubt its a very frustrating to have the annoying hard braking...
I have been able to feather it smoothly, but it does not take giant throws of the sticks to get it to act up either, even worse on windy days and confined operating areas...
Also dispise how with every firmware upgrade you have to enable multi modes as well as turn off coordinated turns.... Those turns make me sad hahahaha
But as for EXPOS, they use to work wonderfully when I flew RC helicopters to "soften" the center point and makes it smoother around the stick movements for the sticks center point.... Then you could of course program a few profiles change it as you needed for your intended type of RC flying...
However I agree GAINS wont do anything to help with this problem or anything on the drone for that matter....
2-8 05:43
