Careful not to charge Pocket 3 with PC on USB
1090 4 2023-11-11
Tide
South Korea
I was charging my Pocket 3 with USB cable pluged into my PC.
But after an hour, it stops charging and turned on.
You know what happen when it turns on.
Gimbal rotates.
Pocket 3 was lay down with USB plugged into its bottom USB port.
And gimbal rotated to push Pocket itself around.
It would be problematic if Pocket 3 was inside the case and gimbal motor strained or it rotated itself off the table.
I could have been just my computer or the USB connection issue but any of the other issues should turn the camera on.
So be careful when you charge your Pocket 3 on PC.
2023-11-11
Rishio
Taiwan
Yeah, I feel a bit nervous when plugging in something to the usbc, so I always take it out of it’s case and make sure the head won’t get damaged by turning in an unexpected way.
2023-11-11
Andreas Dueck
Switzerland
The Pocket 3 switches off the gimbal when it detects resistance, but I do the same thing. Safety first.
2023-11-11
DowntownRDB
Flight distance : 1722 ft
Thanks for the heads up.
2023-11-11
IftiBashir
I usually have the unit on its tripod and the small extension when charging, with no case.
2023-11-11
