Dji avata charging station missing
264 3 2023-11-25
Nijam219
Flight distance : 5443 ft
Hi i forgot my charging Adapter for the avata batteries...is there an Option To load it without the Adapter?
2023-11-25
DJI Susan
Hi there, the DJI Avata Battery Charging Hub/Adapter support the PD fast charging protocol. The max charging power of the DJI Avata flight battery is 65 W. So you may try to use a corresponding charger that supports PD fast charging to charge the battery.
It supports non-standard chargers (including QC fast charging) as well, yet the charging speed may be slow (5 V/2 V, 5 V/1 A), if there is no charger, you can use the computer USB ports and other charging methods. Hope this is helpful.
2023-11-25
Nijam219
DJI Susan Posted at 11-25 20:00
Problem is that i forgot the Hub/Adapter....
2023-11-26
DJI Susan
Nijam219 Posted at 11-26 00:12
I see, I am deeply sorry for misunderstanding the issue in the first place. As it requires a dedicated adapter, if needed, you may try to see if there is a DJI store nearby and purchase it.
https://www.dji.com/uk/where-to- ... ite&from=footer
2023-11-26
