FW question - newbie
390 7 2023-12-4
awsmits
Hi, please bear with this newbie as I try to learn about the DJI system. Just bought the Goggles v2 off ebay and am learning about FW that I need. I plan to use the goggles with both the caddx air unit and also the O3 air unit (for fixed wing airplane FPV). I read that there are two FW versions on the goggles v2, but all I see reported in the settings is FW 1.06.00.00. Are there different FW for the FPV and Digital FPV systems, and how do I determine what I have. Confused!
2023-12-4
Depp
Flight distance : 1868796 ft
For the vista you need the second to last. Don't know the numbers but don't get the newest.
2023-12-4
awsmits
I heard that, but how does one determine what FW is on the goggles? I only see 1.06.00.00.
2023-12-4
DJI Natalia
hey Captain, thank you for your question, l have forward to the engineer, we will get back to you once we have the answer. thank you so much for your patience.
2023-12-5
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. If you are planning to use the DJI FPV Goggles V2 with your DJI FPV System/Vista Air unit, you must use the firmware v01.00.06.08 on the unit to ensure connection with the Goggles. If you have other inquiries, feel free to contact us. Have a nice day ahead.
2023-12-5
awsmits
Thanks for replying, I appreciate it. However, I don't think you've answered my question...that is, how does one determine the FW on the goggles? If I go to Settings in the goggles, it says FW Version 1.06.00.00. If I use DJI Assistant, it confirms that I am on FW Version 1.06.00.00, with an upgrade to 1.07.00.00 possible. So would I need to downgrade my goggles to 1.00.06.08? I don't see how to do that in DJI Assistant 2.
2023-12-5
DJI Natalia
Thank you for your answer, DJI FPV goggles V2 with DJI O3 Air unit and DJI digital mapping system (caddx air) need to switch models, after switching models, the firmware version of the glasses is different.
Switching path: Settings-About-Switching Models
2023-12-5
djiuser_lysYEf6fQzLI
Thank you for that response. As you directed, when I change models in the goggles menu and report, the FW of the goggles does not change. So I still don’t see how I can downgrade just the Vista model mode.
2023-12-7
