DISCONNECTION ISSUE AFTER FIRMWARE UPDATE
619 5 2023-12-14
Crispolo
Flight distance : 1134980 ft
Philippines
Hi there, I'm getting a disconnection issue after I update the remote firmware from 04.11.0200 to 04.11.0200. also updated to the latest version of dji fly app and may mini 2 se firmware version is 1.00.0360. also tried to revert back the firmware of my remote to 04.11.200 but no luck. I'm flying on the same spot so I know that there is no signal disturbance in the location. No luck it's not as good as before the update. Dji please fix and help me.
2023-12-14
DJI Gamora
Hi, there. Sorry for the inconvenience. Please go to System Settings> Transmission> Select Dual Band> Auto. Kindly keep us posted on the latest progress.
2023-12-14
Crispolo
Philippines
I already selected auto and Im using auto always. I also tried manual and select 2.4Hz and also tried 5.8Hz but no luck. Dji should be responsible on scenarios like this. I see many users saying that they are getting issues like this after firmware update and I don’t believe them since I always update firmwares of the my very own drone, until thing's like this happened to me.
2023-12-14
Junior - Brazil
Flight distance : 476483 ft
Brazil
If it took too long with the drone turned on during this firmware update, I'm sorry to say, it probably must have caused a component to burn out. Here in Brazil, many people have been complaining about this problem and there are now workshops specializing in replacing the component. I went through this problem myself, the board of my only drone, a Mavic Mini, burned out, which I sold and bought a 3D printer where I developed and sold a cooling base to help with these updates: it's my way of protesting this chronic failure and trying recover money thrown away.
I wish you good luck.
2023-12-19
ImFlyImPilot
Flight distance : 116470 ft
I had that issue as well, i also had trouble connecting to GPS satellites initially.. I just restarted everything, reconnected my RC and recalibrated everything, compass calibration and all. I’ve put on a couple miles since last night, and no more issues so far. Goodluck!
2023-12-19
cyan
Ban Posts
Flight distance : 202326 ft
1-7 15:46
