Popup after firmware and DJI Fly update
1973 23 2023-12-27
hillbillyflyer
Flight distance : 360505 ft
Ever since this last update I get the pop up pictured when I attempt to manually start the props or use auto takeoff. How do I get rid of this? I have disabled "flight tips" in my profile.
2023-12-27
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. In order to take into account diverse user needs and sufficient safety guidance, Therefore, you will be asked to confirm this prompt before each flight. When taking off with a stick command/one-click takeoff on the APP/waypoint flight, a pop-up window will prompt you to choose Normal Mode or No Position Hold mode. If you select Normal Mode, the aircraft can hover stably; if you select No Position Hold, the aircraft cannot hover stably, which may affect flight safety, so please choose carefully. Hope this clarifies your query. We appreciate your valued support.
2023-12-27
hillbillyflyer
DJI Paladin Posted at 12-27 21:16
Why are only some people seeing this popup?  The whole thing is weird. Just put an option in the setting for position hold and normal. Dont make me pick every single time I use my drone.
2023-12-28
Manitobahunter
hillbillyflyer Posted at 12-28 05:30
Been doing some thinking about how you can get rid of the popup, I don't know if any of this would work but, heres a couple pics of my controller screen, not sure if it looks the same on your I pad with the fly app as on my RC2..
Make sure thats not disabled.
I found this in my flight settings, I clicked on it to see what would happen, got that and when I hit skip, it gave me a check box option not to see it again.
This is the one I mentioned before in the profile settings
2023-12-28
DJI Paladin
hillbillyflyer Posted at 2023-12-28 05:30
Thank you for your response, hillbillyflyer. In order to take into account diverse user needs and sufficient safety guidance, Therefore, you will be asked to confirm before each flight. However, we will gather this suggestion of yours and will forward it to our relevant team for attention. We appreciate your understanding.
1-1 04:07
smbishop
Flight distance : 1859232 ft
I get this as well, now I know why...
1-1 07:38
dwabrams
Flight distance : 1235961 ft
I've seen no difference in the performance of the Mavic 3 Pro when I engage the No Position Hold Mode. The drone still maintains its position well. Has anyone else tried it?
1-10 09:23
Mobilehomer
Flight distance : 18150351 ft
DJI Paladin Posted at 1-1 04:07
NOT a satisfactory answer!!! There is ZERO difference in flight or position hold ability regardless of choice. I have tried both ways on Mavic 3 Classic at altitude to check VPS or GPS position hold. BOTH are perfect. The warning is totally unnecessary!!!
1-10 09:30
dwabrams
Mobilehomer Posted at 1-10 09:30
It's not just a warning. It's a user input box, requiring that a selection be made. But, as you say, there's no apparent difference in the two modes.
I just checked the latest (12/27/23) of DJI's release notes and the user manual. There's nothing in either about NPH. DJI has really dropped the ball on documenting this new "feature" and communicating with owners.
1-10 09:33
Manitobahunter
Just a thought, if you're feeling brave, try refreshing the firmware on your mini 4 with the DJI assist 2. I got the Integra goggles, and motion 2 and had to update them through the DJI assist 2, it took 2 tries for the goggles, but the motion 2 worked first time and they seem to function normally.
1-10 13:14
DJI Paladin
Hello, Mobilehomer. We really appreciate your feedback regarding this matter. Rest assured that this concern will be coordinated with our relevant team for attention. Thank you for your understanding and support.
1-11 22:37
Robert Mitchell
Since the last update, I get that screen every time I start up and want to fly. It's so incredibly annoying and makes no sense. Make it a preference or a setting but not something that we do every time we start a flight.
1-29 16:09
DJI Tony
Robert Mitchell Posted at 1-29 16:09
Thank you for your recommendation. This will be forwarded to the designated team. Rest assured all customer feedback is considered to improve the products and services. Have a nice day.
1-29 21:11
gary h
Flight distance : 4833747 ft
I too would rather see it in the settings to be set ONCE as a global setting -- not on every flight. That dialog box catches me every time I attempt to start the motors, and nothing happens. Annoying! (and apparently it won't change anything for me with a Mavic 3 using a smart controller.)
2-3 15:24
2sticks
Flight distance : 131355 ft
This screen needs to be eliminated…….period, why does DJI feel the need to flash this dialogue box regardless of experience level.
2-3 15:30
djiuser_59ie2iDtSCew
I get the same message - even though my controller is in normal mode.
2-3 17:08
fans784f71b4
Flight distance : 46798589 ft
This is a big and needs to be fixed you are not helping anyone by adding this you are just getting in the way of people trying to do a job with this done!!! It needs to be able to be turned off permanently and stop saying it’s to protect anybody it’s just a bug!!!!
2-18 09:36
fans784f71b4
DJI Paladin Posted at 2023-12-27 21:16
This response is abject nonsense!! The warning is a mistake! You need to fix this. Let’s look at the facts: even though position hold is already turned on in the dji fly app you still give us this warning and make us select something that is already on! This should only display if position hold has been turned off otherwise it is just a waist of time! I hope you get flooded with complaints about this so you will fix it.
2-18 10:58
DJI Paladin
fans784f71b4 Posted at 2-18 10:58
Hello there. My apologies if the response did not meet the expectations. Please allow me to record this concern of yours as a suggestion and forward it to our relevant team. If you have other inquiries, feel free to contact us. We appreciate your understanding and support.
2-19 02:12
fans784f71b4
At the very minimum it needs a “do not show me this again” button
3-16 06:52
fansc1642763
Stupidest thing ever added to this drone. I lost a $650 fliught today because this message popped up and it was frozen on my screen with no avail. I  power everything off and the same thing again. Now its not freezing anymore but nonetheless it caused me to pack up apologize to my client and go home. Wow...just wow. These people do not know much about UI/UX. Nothing. If DJI listened to just one of the folks who recommended stuff would be great.
4-4 19:53
West End Drone
New Firmware update apparently has resolved the issue with Flight Safety Tips pop-up.  Normal mode now shows as "P" mode
4-12 03:48
DJI Paladin
West End Drone Posted at 4-12 03:48
Hello there. Thank you for reaching out. Please provide us with the following for further investigation:
App version used:
The firmware version of the drone:
4-13 01:16
