DJI Gamora
Hi, there! Thank you for reaching out. The files under the "Aircraft Album" are only cache files that allow you to preview your recently filmed by your aircraft. The high-resolution files will be stored through either the internal storage or the micro SD card of the aircraft. If you wish to transfer these original files, you may consider using the QuickTransfer feature. You may follow the instructions below;
1. Power on the aircraft and wait until the self-diagnostic tests of the aircraft are complete.
2. Make sure Bluetooth and Wi-Fi are enabled on the mobile device. Disable the cellular/mobile data of your mobile device. Launch DJI Fly and a prompt will appear to connect to the aircraft.
3. Tap Connect. Once successfully connected, the files on the aircraft can be accessed and downloaded at high speed. When connecting the mobile device to the aircraft for the first time, press and hold the power button of the aircraft for two seconds to confirm.
Please feel free to reach us if you have further concerns. Thank you for your support. |
