Mavic 3 Purple hues and banding in the sky - just sell it?
359 11 2-18 22:50
Brains2
Flight distance : 548222 ft
South Africa
I have been waiting months/years for a fix to the Mavic 3 for the purple hues and banding in the sky issue when using D Log. All I can find online and in threads here are promises by DJI that it is not a hardware issue and is a firmware issue and they are going to sort it out but no fix has been given which by now must mean DJI cant fix it or does not want to.
The Mavic 3 Cine and the Pro appear to have the same issues and no fix. Before I dump this product as defective and look for a product that does work, does anyone have an input or a solution for this problem? Really disapointing for a product using a Hassleblad camera that showed so much promise.
Note - All firmware is up to date.
2-18 22:50
DJI Tony
Hi there. We understand the inconvenience. Does this issue show up in ISO 6400 24 fps? If so and you already tried updating or refreshing the firmware, please send the aircraft back to DJI for further inspection. You can submit a Repair Request on the DJI website or use this link: https://repair.dji.com/. The warranty can be applied depending on the assessment's outcome, including your unit's warranty period. We appreciate your patience. Have a great day ahead.
2-19 01:05
Brains2
South Africa
DJI Tony Posted at 2-19 01:05
I film only during good sunlight conditions at 30fps and ISO is at "auto" (the ISO couldnt exceed 400 in those conditions) and as stated, the firmware is updated, so the answer to you question is no. Do you have any other solutions?
2-19 02:03
DJI Tony
Brains2 Posted at 2-19 02:03
Do you have any sample photos? I will forward this to the relevant team to check. Thank you for your patience.
2-19 02:22
Brains2
South Africa
DJI Tony Posted at 2-19 02:22
The problem is when using D Log as stated, so what I think you mean is video. What I can do is take screen shots of a video with this problem. If more are needed there are many more examples of this complaint on this forum already. Please see attached.
2-19 04:05
ZmoothOperator
Flight distance : 187516 ft
Norway
Are you saying that this banding is in the original file, prior to any processing? I can only make such banding appear if I render to 8 bit video...
2-19 14:05
Killerbee
Flight distance : 64820 ft
Also, what videoplayer are you using?
2-19 14:10
Brains2
South Africa
ZmoothOperator Posted at 2-19 14:05
Thats hard to say or see as the original D Log file is as a D Log file is, grey and without any "definition"  The snap shots above are the orignal file with the DGI LUT applied. If I try using my own color correction without using the DJI LUT, I have the same results. I will have to check what bit rate is being used.
2-19 23:17
Brains2
South Africa
Killerbee Posted at 2-19 14:10
Filmora 13 is being used
2-19 23:21
Brains2
South Africa
Heres the strangest thing - so I opened up the project that I took those snapshots off from yesterday and all the purple hue and banding have disapered completely, so my problem seems software related, what changed overnight is a mystery to me as I have had this issue for a long time and seen it when going back to the same footage more than once over a period of more than a year. I deleted that project, opened a new project, imported the same footage and it all seems good. I never had this issue using the Air2s and only the Mavic 3 which only adds to the mystery, lets hope my problems are over even tho I cant explain what happened to fix it :-)
2-20 00:27
Brains2
South Africa
Hi Tony, as posted above the issue seems to have been rectified
2-20 00:39
DJI Tony
Brains2 Posted at 2-20 00:39
Perfect. Please keep us posted if the issue persists. We appreciate your valued support.
2-20 02:52
