fanse68b7f05
Flight distance : 476867 ft
Panph Posted at 2-21 04:59
It can be the distance cut as AR sayd, or looks like a positioning error. Once i processed L1 dataset with RTK errors and were looking the same. Check the quality report of the mission, but pretty sure RTK Fault.
You can fix PPKing the dataset, with a rinex, if available.
I agree with this. It doesn't matter if you saw "fix" while flying. Check your quality report and post it here. You'll likely need to PPK the dataset, as Panph suggested. |
