ageelectrical
Havering the exact same problem only I have also lost my video transmission gimble still works ,noticed the dd-did did not sound the same as when I updated to 1.3 I have tried a couple of things but can't get the vid feed back I installed the new 1 4 version on to my ss card on the root dir ,bird started the dddd an then ddd ddd funny iv never herd this on before yellow light flashing ,sad car stated on new writen fill that software was same as installed and aborted I have also noticed the battery charging light sequence is not correct does nolonger show the charge status only 1234 light flashing even when fully charged ,vidio worked for about five minuets the vanished off my screen the controls ang gimble can still be moved and are under my control so tried tried to revert to 1.3version to try ang get my bird Bach to what was a fully working bird , reinstalled 1.3 onto the SD card switched off RC installed at this point you force bird to read the SD card and not sit withe the yellow light flashing trying to locate the RC unit so you pres that little button on the inspire this will delete the connection from the RC switch off then switch back on it will then reinstall previous version which went ok ang the fill saying that it had installed Then turned on RC and from the app new connection LINK RC bird was found no problem and vidio feed was reastablished for about 10minuits the disappeared again . At this point I decided to give it a rest after hours of piz around ,but went back about a hour later same again happened vid for about 10mins then blank screen ,have also noticed the rear fan on the camera is not running but can hear something inside as if their is another fan inside , my conclusion is that this is one of two things either when uploading updates it still retaines its main software like when you update windows and their is now a issue within its program and needs a clean install or the cam electronics are switching the vid feed off like its overheating ,not that I can see signs of this as it's not on long enough ,well as dji don't seem to want to tell anyone how things are controlled and their is no info on reinstalling previous versions thought I'd give you all a bit more info on how to go about. Any ideas on the vid feed would be much appreciated . |
