Are we ever going to see Fuji X-H2 and X-T5 compatibility???
367 3 4-10 18:43
CR PHOTO
New Zealand
DJI - I cannot fathom why we are still waiting for RS3 Mini compatibitly with the Fujifilm X-H2 and X-T5. These are not new cameras now and are both extrememly capable, highly specced & poplular video cameras and don't connect via USB or Bluetooth to the Mini.
Is there something you need from Fujifilm to make them compatible? The reply from DJI to every other post here about these cameras either says "it's the same as the X-H2s" - it's NOT and doesn't work, or worse "check our compatablilty list" or "we'll talk to our engineers". I also notice even the brand new Ronin 4 isn't compatible - what's the story DJI???
Seriously I'm about to give up waiting, sell my Ronin and go and buy a ZHIYUN gimble because they ARE now compatible with both these cameras!
4-10 18:43
ResonatorUAV
Flight distance : 1700502 ft
I kinda feel the same way,  if DJI does not provide support for the FujiFilm XT5 on the RS3 Mini then I will happily sell the gimbal and look elsewhere.
Previously I was using it on my XT3 and it was fine. I need to see some movement on this issue because we have been waiting around for too long.
4-11 02:14
CR PHOTO
New Zealand
DJI are you there????
A reply would be nice!!
4-15 19:53
djiuser_ILebIDMeoT3o
Cambodia
all the vendors dump on x-h2 because sales numbers are not high enough for marketing team to get out of bed creates lots of ill will for DJI
and come on it's only a bluetooth interface and I am sure Fuji provided simple api
and don't assume other vendors are any better
after months of back and forth with feiyutech they finally had 'support' in firmware and correct cable but the gimbal won't level properly and wanders constantly so I just gave the POS away
4-20 03:10
