Lifting load
2102 12 2024-4-17
UAViator53
Flight distance : 692090 ft
Was is the lifting capacity of the M350?
2024-4-17
Johnnokomis
Flight distance : 14031719 ft
2.7kg officially. Though it has the ability to lift almost double that.
2024-4-17
UAViator53
Johnnokomis Posted at 4-17 09:50
Thanks for the quick response.
2024-4-17
patiam
Flight distance : 1156358 ft
Just chiming in that lifting capacity is generally different than gimbal sensor payload capacity. The aircraft can lift/carry a heavier load than it can support on the gimbal (usually).
2024-4-17
UAViator53
patiam Posted at 4-17 19:56
Just chiming in that lifting capacity is generally different than gimble sensor payload capacity. The aircraft can lift/carry a heavier load than it can support on the gimble (usually).
Thanks, appreciate taking the time to assist.
2024-4-17
DJI Gamora
Hi, UAViator53. Thank you for reaching out. The aircraft has a max payload capacity of 2.7 kg, meeting the needs of different operation scenarios like public safety, inspection, and mapping.
2024-4-17
LV_Forestry
Flight distance : 4726654 ft
Latvia
You can lift a lot more than 2.7 using the set of screws that are under and on the drone. You can even attach it to the landing gear.
The max I put on an M300 is 3kg500. Flight time is not affected too much.
It's up to you to test the maximum flight time of the drone with what you want to put on it.
Important:
-Respect the center of gravity
-If you suspend a load at the end of a rope, pay attention to the pendulum, it doesn't really like that.
2024-4-17
UAViator53
LV_Forestry Posted at 4-17 21:13
Thanks. I have lots of experience with the M600 & sling loads with the Fire Department. They are looking at a replacement heavy lifter for the 600 and asked about the 350 since the 600 is not manufactured any longer.
Thanks for the input.
2024-4-17
UAViator53
DJI Gamora Posted at 4-17 20:33
2024-4-17
LV_Forestry
Latvia
UAViator53 Posted at 4-17 21:26
Have you looked at the the DJI Fly Cart 30 ?
2024-4-17
UAViator53
LV_Forestry Posted at 4-17 21:29
No, Never heard of it; will check it out. Thank you.
2024-4-17
UAViator53
UAViator53 Posted at 4-17 21:31
$20K...Ouch.
2024-4-17
DJI Gamora
UAViator53 Posted at 4-17 21:29
You're most welcome, UAViator53. Should you need further assistance, please let us know. Happy weekend!
2024-4-19
