I was testing my Phantom 3 Advance last Saturday, ascending to a few meters up, camera facing down and started pulling it down and everything is working fine.
When i was doing another round of testing yesterday (a different location), same process, ascending to a few meters up, camera facing down and started pulling it down. I noticed at some point the camera moves left/right for a bit.
Not sure if this is normal? gimbal issue? Needs calibration or just wind effect? Any thoughts?
How fast was the descent? Did it do the same during the ascend? Does i ...
Thanks for the reply.
Not so much wind down (though not sure at the altitude where there was shakey motion), as evident the trees are not moving. Descent is slow /light/normal.
Ascend is working perfectly. I tried POI circling (lower altitude compared to the shakey motion) height and it is perfectly working fine.
From the other videos, gimbal looks OK.. From the video of the original issue it looks lke the gimbal is anticipating YAW. If you use an android device you can turn that off in the App ( not available to IOS devices yet for some reason )
sploodge Posted at 2015-9-14 10:05
From the other videos, gimbal looks OK.. From the video of the original issue it looks lke the gimba ...
in IOS, the setting is called "follow" or "fpv" if i remember correctly... One mode will tilt the camera with directional change, in the other, it maintains a flat horizon. This could possibly be what he is experiencing.
