New to Avata 2 question about remote
456 11 7-5 10:00
Hallmark007
Flight distance : 12400594 ft
Quick question is Avata 2 compatible with Controller 2 ? Or do I need to wait for controller 3
7-5 10:00
Swedrone
Flight distance : 15136368 ft
Sweden
Seems so
7-5 21:14
DAFlys
Controller 2 needs goggles 2 to work with the Avata 2,   if you have goggles 3 you need controller 3.
7-6 00:38
Hallmark007
DAFlys Posted at 7-6 00:38
Ahh was thinking there was a problem with it. When avata 1 came out I bought the combo of 2 batteries charger and remote but never got around to buying the drone I have now just purchased the avata 2 but remote is not available. Ill just have to wait no hurry have never flown these drones …
7-6 00:43
DAFlys
Hallmark007 Posted at 7-6 00:43
They changed the remote with the Avata 2,  its now uses a bluetooth chipset and talks only to the goggles that relays the control signal.  The Remote 2 talks OC directly to the drone.
7-6 00:50
Hallmark007
DAFlys Posted at 7-6 00:50
Cheers thanks for that.
7-6 00:51
designrs
That would probably explain why the battery in the Controller 3 lasts so long!
7-6 08:04
Swedrone
Sweden
designrs Posted at 7-6 08:04
FPV RC 2 vs RC 3
346 vs 240 grams
9 hours vs 10 hours operating time
2 batteries inside the handles of the RC instead of 1
What amazes me is that the FPV RC 2 is actually transmitting to the drone whereas the RC 3 only communicates with the goggles so should give you 4,5 hours but by not radioing the drone it gives you 10 :-)
7-6 22:46
DJI Natalia
Hi there,
DJI Avata 2 is compatible with DJI FPV Remote Controller 2, DJI FPV Remote Controller 3, DJI RC Motion 2 and DJI RC Motion 3.
Note: All FPV drone is required to be used with DJI Goggles.
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
7-6 22:48
DJI Natalia
Thanks for sharing this information! It will definitely be helpful for others on the forum. Have a great day! Thank You!
7-6 22:49
DAFlys
Controller 3 only has 1 battery now too, the version 2 controller had two cells in it.
7-6 23:10
Antdrones
Flight distance : 1017274 ft
You need the goggles 2 to match the remote 2, otherwise goggles 3 needs to be paired with controller 3
9-16 09:23
